  Soarer Central * Mechanical - TT * General Mechanical * Floded Engine Previous Previous    Next Next
Open in new windowArchive through February 09, 2010Garth Williams24
Garth Williams
jamaica
tt
Reg: 09-2008
Tuesday, February 09, 2010 - 03:20 pm, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it was said in a previous post that the emanage blue retains the cold start programs so it should not make any difference and my car was been flooded on starts not while driving,
James Wilson
sa
Reg: 10-2008
Tuesday, February 09, 2010 - 03:27 pm, by:  James Wilson (Ser493) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you may have shorted it out and corrupted the tune? I would be checking ignition system too if you shorted it out.
Garth Williams
jamaica
tt
Reg: 09-2008
Tuesday, February 09, 2010 - 03:29 pm, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok i wont touch the screws, i also have another ecu do u think i should give it a try?it it the original one i got with the car i had a problem some months ago thaught it was the ecu so i got a replacement it turned out to be the bridge for the fuel pump. and i just never put the original one back, i think the flooding problem started some time about then but i cant remember it it was before or after the ecu swap.
Garth Williams
jamaica
tt
Reg: 09-2008
Tuesday, February 09, 2010 - 03:32 pm, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
coil and igniter i guess? it boost and run fine other than the error in the dash and the start up problem.
Rob Rojo
Reg: 12-2007
Tuesday, February 09, 2010 - 03:50 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you have a plug in loom just remove the Emanage and see how it runs with the stock ECU running the show.
If it runs fine without it then you know its a problem with the EManage.
James Wilson
sa
Reg: 10-2008
Tuesday, February 09, 2010 - 03:56 pm, by:  James Wilson (Ser493) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep that's your answer to eliminate the e-manage as the source - good thinking Rob
Chris Prak
JZZ30 Soarer - Twin Snails
Reg: 12-2006
Tuesday, February 09, 2010 - 07:42 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Diagnostics like this is very hard to do Garth. It could be many things, and until you eliminate the most probable part from the question, then you will keep chasing the problem in circles forever.
I would start by ditching that relay and using the standard Fuel ECU, Cleaning the injectors and testing for flow etc, then quite possible, fuel pump. In any order, which ever is easiest for you.
Garth Williams
jamaica
tt
Reg: 09-2008
Tuesday, February 09, 2010 - 11:02 pm, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
fuel pump ecu is fried and not easy to find as the soarer is not a common car in jamaica, i also didnt know that the car would run if i unplug the emanage as wires were cut and spliced with the emanage loom but i guess i will try it could not hurt.
Rob Rojo
Reg: 12-2007
Wednesday, February 10, 2010 - 07:06 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If the Emanage has been spliced into the factory harness the car will not run without it.
It might be worth getting the Emanage software and cable to. At least then you can access the logging to see if the emanage is the problem.
To confirm that it is actually flooding couldn't you just remove the plugs to see if they are wet before starting?
It could be several other things like a stuck ISCV or faulty TPS.
It would make sense that if the ISCV is stuck shut or not opening fully that you would have to open the throttle to get it started, so that is what I would be looking at to start with.
Garth Williams
jamaica
tt
Reg: 09-2008
Wednesday, February 10, 2010 - 08:04 am, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have already change the ISCV and the injectors and the coolant temp sensor in search of the problem,i also know that the ISCV works cause it does idle higher on cold start i dont think there is a manual way to make it idle higher without affecting the idle when its warmed up, on cold it idles about 12000 rpm warms up to about 800 rpm, i know for a fact that it is getting too much fuel in the motor, i can make it stall if i repeatedly tap the throttle while under some load, it does it sometimes while i am backing into my drive way.i realy appreciate the help of all you guys , its just frustrating to not be able to fix this problem i suspect the ecu but i want to make sure i got my original injectors back in before i chance the ecu.
James Wilson
sa
Reg: 10-2008
Wednesday, February 10, 2010 - 08:12 am, by:  James Wilson (Ser493) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What a pain, I think investing in the software and cable for your E-manage could be the go...
http://www.nengun.com/trust-greddy/e-manage-software
$107us to eliminate your E-manage, might be the best option if it's been spliced into your loom.
Garth Williams
jamaica
tt
Reg: 09-2008
Thursday, February 11, 2010 - 02:54 pm, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i went to bed i and thought of something while half asleep, it reminded me of a car that came to a shop i was working at the time, it had a similar problem, after many days we figure it out, the fuel pressure regulator was some how blocked and that caused the fuel pressure to be too high that the ecu could not handle so it was flooding too, that is something i will look into as well,
Garth Williams
jamaica
tt
Reg: 09-2008
Wednesday, February 17, 2010 - 12:17 pm, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well the fuel flow behind the fuel pressure regulator was fine so that is not the problem, but i found out why i got the error in the dash, the monkey\mechanic who changed the injectors broke the plug off the knock sensor to the rear so that was a easy fix, now the car drives even better, it is still rich and will flood occasionally on start up even after i reset the ECU so i figure the emanage needs to be tune? that"s the only other thing i can think of. and one have other idea?
