Tuesday, February 02, 2010 - 08:07 pm, by: Tyson Adams(Sonnyraven)
hey guys, i have a jz330 soarer, 1jz, auto with some problems.. when accelerating from stand-still it revs through first gear fine (a little slower than usual though) then seem to get stuck in second gear and harldy accelerates at all. I thought it was definately a gearbox issue but then when i put it into neutral it will not rev properly either which leads me to believe it may be engine related. At no point does the boost go past 0 psi. any help would be much appreciated.
Tuesday, February 02, 2010 - 08:16 pm, by: Daniel Clarke(Dieseltrain)
Either you have blown off an intercooler hose, Map sensor vac line has come off, map sensor faulty , Possibly blown the turbos and the ex wheel is stuck in the cat convertor blocking it causing it to not want to rev .
Check all intercooler hoses and clamps, and all vac lines in the engine bay as well as the map sensor line firstly .
