  Soarer Central * Mechanical - TT * General Mechanical * Brake booster outlet for 2j manifold??? Previous Previous    Next Next
Aaron Casey
Wednesday, February 17, 2010 - 09:01 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
quick question is...
im upgrading to a 2j from an aristo motor with trc has no outlet for the brake booster.
ive seen alot of people tap into the top of the plenum. but i dont like the look of it. i was thinking trying to tap into the rear of the plenum at the flat bit at the back.
will that part of the plenum be thick enough for the banjo bolt?
