Friday, February 19, 2010 - 07:35 pm, by: Shane Haverkamp(Havabeer)
hi everyone
trying to sort out a studder/vibration in my soarer this arvo and in doing so i took off the exhaust pipe with the cat attached to it
just after the cat there is a sensor, very similar to what an oxygen sensor looks like except longer, its only 2 wire (black and white) the normal 02 sensor is still located up near the dumps
what is this sensor? also pulling it out of its housing it actually become damaged, seems i tiny part of it had fused to the housing pipe and ripped a small chunk off the sensor its self. any idea's on what it is so i can try and replace it? am i right in assuming its just another o2 sensor for after the cat?
car is completely stock Twin turbo non vvti 1992 soarer.
Friday, February 19, 2010 - 08:38 pm, by: Boris Siljanoski(Z2tt)
This is a temperature sensor. When abnormal temperature is detected, a light will appear on your dash to let you know that your catalytic converter has failed, or if the exhaust wheel blades from your turbochargers have made their way down there.
