  Soarer Central * Mechanical - TT * General Mechanical * Automatic Transmission Electrics Previous Previous    Next Next
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Saturday, April 03, 2010 - 08:57 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
Been working on the 1JZed again and we've stumbled on a new problem that we'd not noticed before. We just tried to drive it up the driveway, well, but it doesn't move!
You see, the transmission isn't selecting gears. Now the selector itself moves the point at the gearbox. But you have to understand the electrics of this car are a bit butchered as most of it wasn't really applicable anymore.
So what we have: Regular Automatic ECU is connected. No other types of ECU's are. The Park Neutral switch is hooked up, so the car can start when in park or neutral. And that's about it. Obviously there is a ECT transmission ECU, but we've not actually used that at all. It was one of the parts we boxed away and cut the loom.
Now we've noticed we can't shift into any drive gear and have it spin the wheels, is the ECT ECU necessary?
We've another theory. I made an assumption that the brake switch which releases the shifter from park and allows you to go to R or D etc was a purely mechanical switch. That is it only flipped a toggle out of the way to release the shifter. But does this actually have a secondary wire or something to the Transmission to stop it from choosing gears? Obviously if that's the case we'll have to jimmy up something to trick it, or install some kind of switch ourselves.
So that's about as much info as I can think of that's relevant. The engine was swapped over, the transmission was swapped over and the electrics butchered. Should be all fine right?
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Saturday, April 03, 2010 - 10:27 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd think if you have no ECT ECU connected in, it should still shift into drive and run, but won't be able to shift to 2nd/3rd etc since the ECT ECU that controls the solenoids to shift isn't there.
Rob Rojo
Reg: 02-2010
Saturday, April 03, 2010 - 10:29 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds a bit confusing,
Firstly what car has the motor been swapped in to?
from the first line sounds like a nissan 240Z or something.
Either way there is no separate transmission ecu as it is integrated on the Main ECU, that is why there are different ecus for the manual and auto transmissions.
What part of the loom did you cut away and why?
the loom needs to be complete to run everything as it should.
The shift lock button is just to release the shifter and has no other connections.
Was the engine and trans separated before installing or was it swapped over complete?
could be a problem with the converter or even as simple as the shifter linkage not being attached.
As Boris said it will still shift into reverse and D but not go through the gears.
Robert Day
v8 & TT
Reg: 01-2007
Sunday, April 04, 2010 - 10:46 am, by:  Robert Day (Lexsmaz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much oil is in the transmission ?
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Sunday, April 04, 2010 - 03:30 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob Rojo wrote on Saturday, April 03, 2010 - 10:29 pm:
Yeah made that assumption already, perhaps hastily.
Everything to do with Electrics not to do with the engine and transmission. So if you think of all those wires from the front fuse box, pretty much everything that didn't connect to the ecu.
So ABS - Gone.
TRC - Gone
Lights - gone
All the electrics inside the car for the dash - gone
When you have a look at the actual wiring loom you'll see its about an inch and a half thick. Its huge. Only about 1/15th of that stuff is related to the engine..
They came together in the halfcut but the shop which did the mounts may have separated them at some point. Obviously that was something we couldn't do ourselves and get engineering approval.
Thats what i thought too, just on the shifter itself.
The linkage is definitely working two reasons - 1) i can see it moving the actual shift bit on the transmission.. 2) Because it activates the neutral/park switch which allows you to turn the car on. If that wasn't being activated then we'd be able to not start the car at all, or start it in any position.
Yeah, well we've been thinking about that... but its not in a location to easily get up real high so i don't exactly want to spend too much time dropping the transmission and diagnosing something. to be fair if its not something we can do at home it'll have to get towed up the (steep) driveway and to a tranny shop.
Robert Day wrote on Sunday, April 04, 2010 - 10:46 am:
It's fine, according to the dipstick.
nissan 240Z
yeah its the 260z 2+2 that i've got in another thread
here. It's a legitimate nissan - it's an import from japan :-)
IF the ECT circuit is incomplete because it isn't sending a signal to the transmission is that an issue?
PS: here's a link for some food for thought, http://jzgte.com/tech/1jzgte/1JZWiringECT.pdf
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Monday, April 05, 2010 - 09:30 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nevermind.
Rob Rojo
Reg: 02-2010
Thursday, April 08, 2010 - 09:01 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So what was the problem with the transmission?
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Thursday, April 08, 2010 - 11:05 am, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dunno just dropped the fluid and cleaned the filter, and filled the fluid back up but used a grease gun to push some through the lines which go through to the radiator. Thinking maybe the torque converter wasn't picking up the new fluid considering it was probably dry for 12+ months...
