Thursday, August 05, 2010 - 11:08 pm, by: Chris Prak(Carizma)
Sounds like mine Guy. It never wants to start and when it does, goes for about 2 seconds, spitting and choking till it dies. It's like it floods the motor. Initial crank with new plugs shows fuel on the plugs, but testing for spark, they are fine. So, I'm planning an engine swap anyway as the compression results of mine were below par anyway.
Thursday, August 05, 2010 - 11:44 pm, by: Sebastian Grant(Saabg)
I had similar problems. Turned out to be the fuel pressure regulator was stuffed and it was leaking fuel into the manifold through the vacuum line. Check your oil to see if there's any fuel in there.
Saturday, August 07, 2010 - 01:59 pm, by: Daniel Clarke(Dieseltrain)
Probably in the coil pack loom, but good to hear its all sorted . Painful as it may have been to replace so many parts, at least you have peace of mind they are all replaced and know it will last a long time
