  Soarer Central * Mechanical - TT * General Mechanical * Coolant idle control bypass and throttle bypass Previous Previous    Next Next
Aaron Casey
Friday, September 03, 2010 - 07:11 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi ive been trying to search around i can remember a discussion a while back but cant find it on bypassing the throttle and iscv coolant lines for cooler intake temps.
what im trying to find is if i will have any issue with idle control with no coolant going to it or any tuning issues.
once i get my engine in i will get it retuned but i want to see if i will have issues so i can run the lines before i put my motor in or bypass them
Aaron Casey
Friday, September 03, 2010 - 07:20 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ahh found it finally!! lol
http://soarercentral.com/sc-forum/messages/51875/214258.html
still doesnt really say if anyone has had any troubles but seems to work fine so i will go ahead and bypass it all.
Jeff Bedsor
Reg: 10-2006
Sunday, September 05, 2010 - 09:31 pm, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No probs here after a couple of years.
Shadi Sabbagh
Soarer TT GT-TL
Reg: 03-2009
Sunday, September 05, 2010 - 09:46 pm, by:  Shadi Sabbagh (Shadz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
same here, been bypassed months ago, everything perfects till now!
Marc Hoffmann
Reg: 07-2009
Sunday, September 05, 2010 - 11:31 pm, by:  Marc Hoffmann (Rushed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
notice any gains, or changes in air temp logs?
Aaron Casey
Monday, September 06, 2010 - 09:43 am, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
awesome thanks guys. i knew the throttle one would be ok i just wasnt sure if the iscv one had a sensor in it to control it or if it was controlled by the ecu fully using the normal engine coolant temp sensor.
