Saturday, September 25, 2010 - 02:21 pm, by: Josh Clarke(Qonder)
Recently went single turbo, Ever since have had a lot of overheating issues. Radiator was boiling into the overflow bottle. and a couple of weeks later it blew the hose to the engine and made a huge mess on the side of the high way, Everytime I start the car I get the oil warning light. All the oil levels are good though. The new turbo is oil cool only would this cause a problem? How can I fix this issue? Thanks Josh
Saturday, September 25, 2010 - 06:19 pm, by: Adam Foster(Adam)
is the oil warning light message oil pressure or oil level? if its level then the sender will need to be replaced, if its pressure take it to the mechanic and get it checked
Saturday, September 25, 2010 - 06:27 pm, by: Josh Clarke(Qonder)
it's the oil level I am fairly sure. On the bottem right of the display, The oil has good levels and is not milky at all, My first thoughts were the thermostat and radiator. But just don't know how to make sure. A new radiator and an oil cooler should overcome this problem though right?
