Sunday, October 17, 2010 - 02:44 pm, by: Milan Dujic(Milan_dujic)
hey guys just did a engine swap in my soarer n i just went to start.i go to start it ignition on all ok then i go to crank it but there is nothing it dose not even turn over. any help please
Sunday, October 17, 2010 - 04:20 pm, by: Walter Gillmore(Cl33pa)
check crank sensor is plugged in, then ignitor, fuel pump prime, starter relay, engine ground cable, starter power, all fuses in the driver side kick panel fuse box.
Monday, October 18, 2010 - 06:56 am, by: Matthew Sharpe(Madmatt)
Where to start! Sorry to sound like an arsehole, but if you ask questions like that without listing the things you have already checked, then do you think you should have attempted the engine swap by yourself in the first place?
Monday, October 18, 2010 - 09:56 am, by: Milan Dujic(Milan_dujic)
ok i got it to turn over but still wont fire.i have checked timing,fuel pressure,spark and compression it is all there and ok any ideas on what i can check before i call a tow truck and send it to a mechanic/auto sparky.
Monday, October 18, 2010 - 02:46 pm, by: James Wilson(Ser493)
Check eci fuse under bonnet, will still spark but no fuel. I think its eci mine did exactly same when i refitted an engine and it turned out to be that fuse. - Maybe this might help.
Other than that just check all the different earth points, there are a few:
one under manifold next to the batery starter motor Back of the block near the head.
How exaclty did you test spark too? I flipped a coil pack and turned the car over and actuallly saw the spark before i ruled it out.
Other than that could be an faulty ignitor, but i would doubt that if you have spark.
