  Soarer Central * Mechanical - TT * General Mechanical * Oil pressure gauge install Previous Previous    Next Next
Kevin Svoboda
qld
1JZ -GTE TT
Reg: 08-2010
Monday, November 01, 2010 - 02:30 pm, by:  Kevin Svoboda (450arn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok dokes, easy as, need some info preferably pics were i hook up my oil pressure gauge, got the shiz for it just no idea on the soarer were ? its a 1jz btw, thanks help would be great
Ben Lipman
Monday, November 01, 2010 - 09:33 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Most of us use a sandwhich plate that mounts between the oil filter and the block.
From memory about $45 on ebay, parts stores etc
Ohh, and unless your oil pressure gauge reads to about 150 psi you wont know what pressure you have at any revs anyway. It will only tell you pressure at idle, or if your pressure is really low. (most gauges run to 100psi only)
Kevin Svoboda
qld
1JZ -GTE TT
Reg: 08-2010
Monday, November 01, 2010 - 10:23 pm, by:  Kevin Svoboda (450arn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
all i need is a line to tap into and a photo of were it is, i got a good idea but yeah, my gauge is full mech, i need a line to tap into thats all, and yeah my gauge is 100 psi
Mark Bryant
tasmania
2jz na/t and tt
Reg: 08-2010
Tuesday, November 02, 2010 - 07:07 am, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi man i have a adapter plate if you want it.it just gets fitted before you oil filter.i'll post some pics up later if you want.
Kevin Svoboda
qld
1JZ -GTE TT
Reg: 08-2010
Tuesday, November 02, 2010 - 02:26 pm, by:  Kevin Svoboda (450arn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah mate, i didnt want to go down that line but yeah, but put pics up and how much u want for it ??
Ben Lipman
Tuesday, November 02, 2010 - 05:07 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can't think off the top of my head of an external oil line to tap into. Everyone I know of has just used a sandwhich plate or a remote filter.
Kevin Svoboda
qld
1JZ -GTE TT
Reg: 08-2010
Tuesday, November 02, 2010 - 05:45 pm, by:  Kevin Svoboda (450arn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah, im goin to do that guys, looked it up and there is a spot to do it but its a mega pain in the ass, just goin to go with the sandwhich plate, just waiting on mark to post back
Mark Bryant
tasmania
2jz na/t and tt
Reg: 08-2010
Tuesday, November 02, 2010 - 07:44 pm, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry man,give us a few minutes and i'll post some pics up.will be $15 plus $5 postage.
Kevin Svoboda
qld
1JZ -GTE TT
Reg: 08-2010
Tuesday, November 02, 2010 - 08:09 pm, by:  Kevin Svoboda (450arn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok mate, if its in good nick ill give u that for it, how does it work btw, does the line go into the adaptor or ??? ive never seen one before
Mark Bryant
tasmania
2jz na/t and tt
Reg: 08-2010
Tuesday, November 02, 2010 - 10:51 pm, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
kevin could you possibly pm or post your phone number?im having trouble posting pics.that way i can send them to your phone.how it works-there is 3 parts adaptor plate,rubber seal and a adaptor bolt.you remove your oil filter,fit adaptor plate with rubber seal where your oil filter was,fit the adaptor bolt and refit oil filter.there is ports in the adapter plate where your oil pressure/temp gauge fittings go.its piss easy man,once you see the pics of it you'll realise.if you can change a oil filter you won't have any trouble.
Casey Perkins
Tasmania
Reg: 08-2011
Thursday, April 12, 2012 - 08:30 pm, by:  Casey Perkins (Caseyp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Salvaging old thread, but I recently bought an oil pressure gauge and I am in a bit of a struggle, where do you guys get your sandwich plates from ? and is the oil pressure sender the bloke under the left side of your intake manifold ?
Darren Bauer
Reg: 04-2010
Friday, April 13, 2012 - 11:38 am, by:  Darren Bauer (Dazmon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are plenty of sandwich plates on eBay, I have been looking too. JDM ones are the go I think. My gauge came with the chunky sender unit, its an extra one to the factory one. Temp sender is next.
