Sunday, February 13, 2011 - 08:36 pm, by: Adrian McGuire(Adro)
hey guys, ive noticed lately when i give my car a gut full she would miss under boost so i went and got a new set of iridium plug thinking the plugs were just getting old but it still happening so i gave the ECU a reset and it still happening. i found if i gradually bring the revs up it seems to be alot better (only missing a small amount) does it sound like time for some new coils?? any advice would be great. Adrian
Sunday, February 13, 2011 - 10:52 pm, by: Brett Harrison(Bretto)
sounds like coils, check for cracks etc, Good preventative maintenance either way, should be around 400 for a new set of those red type, oem are a fair bit more.
Monday, February 14, 2011 - 09:10 am, by: Brett Harrison(Bretto)
Don't reset the iridiums.
If you want to play around with plug gaps, just reset some copper BKR, you can try 0.7mm. But Ive found this is just a band aid fix for weak spark, new coils and .8mm will be fine.
Monday, February 14, 2011 - 09:29 am, by: Adrian McGuire(Adro)
for the moment until i get around to installing the new coils i just wound my boost back to standard (9psi( and it seems to be alot better. ill post up once ive got the new coils in, thanks for your help brett.
