  Soarer Central * Mechanical - TT * General Mechanical * High Idle Previous Previous    Next Next
Ryan Reichert
AB
Reg: 03-2011
Sunday, April 10, 2011 - 09:00 am, by:  Ryan Reichert (Grafik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys I have a 91 TT Soarer.
I'm having a high idle at about 1700rpm in park. I changed 2 of the sensors (The hard to reach ones) but I didn't get the easier one and its a little more expensive.
Would this be the problem or would it be something else? I just want to know before I spend the money on another sensor.
Walter Gillmore
TT JZZ30
Reg: 07-2009
Sunday, April 10, 2011 - 09:49 am, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
which sensors did you replace? would this be a MAP sensor related problem? or the ICV 9idle control valve) gettin stuck? try cleaning the ICV, be careful tho that you dont lose any part of it whilst removing and cleaning
Mark Bryant
tasmania
2jz na/t and rs4 stagea
Reg: 08-2010
Sunday, April 10, 2011 - 11:42 am, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dosnt the 1jzgte have a idle screw on the throttle body?
My on 1jz did and i could adjust the idle there...
Ryan Reichert
AB
Reg: 03-2011
Friday, April 22, 2011 - 09:58 am, by:  Ryan Reichert (Grafik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Where is this screw that you talk about?
Mark Bryant
tasmania
Reg: 08-2010
Friday, April 22, 2011 - 10:14 am, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Look at the throttle body, top left hand side, from memory there is a screw that if adjusted will move the throttle bit where the cable connects and this in turn will adjust the butter fly valve in your throttle body.
Have you replaced or moved anything lately?
Could be your tps but i wouldnt touch this unless your positive what your doing.
Mark Bryant
tasmania
Reg: 08-2010
Friday, April 22, 2011 - 10:18 am, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What were the sensors you changed man?
Ryan Reichert
AB
Reg: 03-2011
Friday, April 22, 2011 - 12:44 pm, by:  Ryan Reichert (Grafik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok well on the 1JZ engine it was the 2 that are hard to get to on the top of the engine. You have to take apart and remove a bunch of lines before you can get to them. I think they are magnetic? I'm not sure because someone else did them for me and said it would probably fix the problem. Unfortunately it didn't but he didn't charge me.
I haven't touched anything lately but i will be fixing my Wastegate soon. I overboost wayyyyy too high so the ecu cuts the fuel.
Walter Gillmore
TT JZZ30
Reg: 07-2009
Friday, April 22, 2011 - 02:22 pm, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sounds like you have a vacuum leak dude. check all vacuum lines into the intake plenum, if your overboosting without any modifications to the stock system, then i would also check the wastegate actuator hoses. also look over your stock BOV lines etc.
