  Soarer Central * Mechanical - TT * General Mechanical * New fan belt Previous Previous    Next Next
Jacob Thomas
VVTi Turbo
Reg: 01-2010
Thursday, May 05, 2011 - 12:34 pm, by:  Jacob Thomas (Jacob_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, just wondering if there is a tool or something i can use to untension the fan belt tensioner.
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Thursday, May 05, 2011 - 01:06 pm, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if the vvti is the same as the standard 1jz its hard to explain but you just put a long ring spanner on it and push down with some force the tensioner is just spring loaded so it will just move in enough to take the belt off.
Jacob Thomas
VVTi Turbo
Reg: 01-2010
Thursday, May 05, 2011 - 02:49 pm, by:  Jacob Thomas (Jacob_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
done and done
