  Soarer Central * Mechanical - TT * General Mechanical * Harness connection to coilpack issue - Photo provided Previous Previous    Next Next
James Tims
TT - Marlew Special
Reg: 11-2008
Saturday, August 13, 2011 - 05:59 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
My car every now and then goes into limp mode because the coilpack connector wire seems to be cracked or it just keeps on sliding off slightly, although today it has happened to me three times, especially after boosting which makes me think it's somewhat related to the harness. Any ideas with what I can do?
Michael O'Driscoll
Saturday, August 13, 2011 - 06:11 pm, by:  Michael O'Driscoll (Remickz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If its the coil pack clip or wire, just replace them?
Do you know for sure? You dont have a faulty coil do you?
James Tims
TT - Marlew Special
Reg: 11-2008
Saturday, August 13, 2011 - 06:41 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When limp mode starts, I get out of the car while it's still running and take off the cam cover, then I just wriggle the wire around a bit until the limp mode sound goes away! I was assuming it was a cracked wire, wasn't sure if it could be replaced! If it was a faulty coil pack I thought it was come on constantly!
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Saturday, August 13, 2011 - 06:46 pm, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Limp mode sound?
Victoria (The Nazi State)
Pretty Red Thing and The Black Beast
Saturday, August 13, 2011 - 09:43 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.ebay.com.au/itm/1jz-2jz-supra-soarer-Ignition-Coil-pack-connector-clips-/290599188210?pt= AU_Car_Parts_Accessories&hash=item43a90fb6f2#ht_500wt_1156
Buy and fit these PROPERLY and it'll be fixed.
James Tims
TT - Marlew Special
Reg: 11-2008
Sunday, August 14, 2011 - 10:38 am, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Dan! I'll give it a shot! Yeah Adrian when the car's in limp mode it sounds significantly different to what the car sounds like when it's running normal. Another alternative is to just check and see if the engine light has gone off :-)
