Sunday, May 13, 2012 - 01:43 am, by: David Kilduff(Turblow13)
Hi all i put the car in to get the ecu fixed last week i got it back and it was still running like crap no choke and idle was up and down i took it back again he FIXED it again and told me im running to much boost and its blowing the spark plug spark out when under boost???, i dont know if this is true or not but when the car went to him it was running perfect untill it went into limp mode the capacitors had leaking and caused some damage.the car had normal idle and no problems under full boost before this and the spark plugs whrer a nice shade of brown and never mised a bet. it now coughs and farts when i give it a boot full.
Sunday, May 13, 2012 - 08:26 am, by: Adrian McGuire(Adro)
Spark blowout does happen. Have you checked your coil pack for cracks? Are the coil clips all unbroken and in good condition? Did u install larger gapped plugs by mistake ?
Sunday, May 13, 2012 - 01:55 pm, by: David Kilduff(Turblow13)
new plugs fitted with correct gap got the iridiums and changed on saturday. has a fuel cut defender fitted the type that fits into the vacuum line, coil packs where checked when plugs done and they had no visual cracks and looked ok will be changing these in the next 2 weeks to new ones and fitted new coil pack clips last year as the original where broken. I have another manual computer coming from sydney so ill swap it with mine this week to see if the one i got fixed was done correctly . if its still running crap i will have to find a good car tuner in brisbane to take it to
Tuesday, May 22, 2012 - 06:57 pm, by: David Kilduff(Turblow13)
Hi all just like to say thanks for the help with the car it still was the same so i took it to capalaba motor repairs and he fixed it it was a cracked spark plug and i had a small boost leak the guys there are realy good and cheap. i also got a dyno to see what its putting out and it was 300hp on 16 psi with a gt35 turbo.
