Friday, September 21, 2012 - 06:34 pm, by: Rocky Horne(Cbf2dy)
Ok after i installed the aftermarket halo head lights i have been getting warning message on my dash saying blowen rear light but all my lights are fine everything works as they should, has anyone had this problem or know how to fix it?
Sunday, September 23, 2012 - 10:06 am, by: Julian Mazur(Jules30)
I got the issue after fitting Supra style lights to the rear. It annoyed me so I cut the wire. On the forum somewhere there is a how to, but on your right hand rear, inside the boot, under the carpet toward where the hinges are, there is a box. Cut (from memory) the purple wire, but look for the tutorial first.
Not sure why headlights would effect your rear lights though. You have the same load, actually more. Double check all your rear globes and if you can't find it, snip the wire.
I did it as I have LED globes and occasionally they work loose, it's annoying having a thing pop up every 3 seconds. I check my lights when I wash it and carry spares.
