Monday, April 01, 2013 - 08:54 pm, by: Darren Bak(Dmb169)
Hi,
i am having an issue the the car similar to another post on here, the car starts fine when cold but after being driven and turned off when i go to start it doesn't want to start up and when it does the revs just drop and it stops.
then i start it again and rev it straight away then it drives normal again.
It is getting annoying now anyone know what it could be? i thought maybe the fuel pump, but not sure. Anyone else have or had the same issue or what i can do to try and fix it.
Also what is the fuel pump bypass i seen someone say in another thread.
After it stalled i started it again and gave it a small rev, worked fine then. This problem only occurs on warm starts when its running it drives fine.
Tuesday, April 02, 2013 - 11:31 am, by: David Ward(Djwtoyota)
I had a similar problem with my 1JzGTE. When it is warmed it goes out of closed look mode (equivalent to a choke) Look for anything that inputs into the running in open loop mode ie MAP sensor etc.
Tuesday, April 02, 2013 - 12:39 pm, by: Darren Bak(Dmb169)
ok i did the the paperclip thing, just let it idle in the drive way turned off waited then turned on and worked fine... so the fuel pump ecu is the problem?
guess ill start looking for a new/second hand one.
Tuesday, April 02, 2013 - 02:12 pm, by: Adrian McGuire(Adro)
i ran with my FP bridged out for over 2 years with no issues. the only downside is the fuel pump is pumping as soon as you turn the key on, even if the engine is not running so if you were to crash you car and split the fuel line, potentially you car would pump your tank dry all over the ground if you didnt turn the key off.
Tuesday, April 02, 2013 - 03:40 pm, by: Darren Bak(Dmb169)
ok done a couple errands today without the paper clip bridge and it didn't stall, tried again when i got back 10 minutes later and didn't stall.... maybe just got lucky but it did idle normal starts at 1k then to 600.
