Sunday, March 20, 2016 - 09:47 am, by: Mike Dunbar(Dunbard)
So after getting in the soarer i could smell strong gas fumes.
Popped the trunk and looked at the fuel tank and over flow line.
First the plastic line had fallen off both sides. One side where it connects to fuel tank and the bottom im not sure where goes but seems to run to a hole to the ground from the bottom of the trunk.
Anyone had this issue? and is where does the over flow line suppose to lead to?
Sunday, March 20, 2016 - 10:59 am, by: Daniel Bonnor(Majorlunacy)
unless the us spec ones are different you should have 2 metal pipes, big = fill to tank, small = tank breather. The plastic line should run from the back/ bottom of fill cap down to underneath the car, it's a drain line so you don't get water in tank (the little hole right bellow fill cap) hope this helps
