  Soarer Central * Mechanical - TT * General Mechanical * 100,000km Service, What Parts Are Needed ? Previous Previous    Next Next
Altaaf Sharif
Reg: 07-2006
Monday, July 31, 2006 - 07:59 pm, by:  Altaaf Sharif (Sharif_dee801) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
I have done a lot of searching on this site and cannot find a thread which goes thru what parts are necessary and or what fluids need flushing with the 100,000kms service.
I would like to get everything that needs to be replaced and have it running perfectly before I mod it.
if
Thanks guys.
Single turbo
Monday, July 31, 2006 - 08:00 pm, by:  James Johnson (Jamesy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if it hast been done in a while just replace all fluids so you have nothing to worry about!
brake
steering
coolant
engine oil
transmission
Altaaf Sharif
Reg: 07-2006
Monday, July 31, 2006 - 08:05 pm, by:  Altaaf Sharif (Sharif_dee801) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok cool what about parts ?
Monday, July 31, 2006 - 08:47 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fuel Filter, Oil Filter, Camshaft Timing Belt ( always good to replace the tensioner whilst doing this, will save you time and money later on) Spark plugs, Air filter. Check your climate control filters also. When they get dirty, they restrict flow through them.
And as James has mentioned, Change All your fluids.
Robert Petrovski
Monday, July 31, 2006 - 08:54 pm, by:  Robert Petrovski (Robche) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
While doing the timing belt it's a must to do the water pump
Altaaf Sharif
Reg: 07-2006
Monday, July 31, 2006 - 08:54 pm, by:  Altaaf Sharif (Sharif_dee801) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How about timing belt, water pump etc ?
When we get a definitive list, how about a moderator makes a permanent thread under the "maintenance category" as it was the first place I went to look for answers on maintaining :D
Robert Petrovski
Monday, July 31, 2006 - 09:04 pm, by:  Robert Petrovski (Robche) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Timing belt
Timing belt tensioner
Water pump
Serpentine belt
Serpentine belt tensioner pully bearing
Radiator hoses
Thermostat
Spark plugs
Air filter
Fuel filter
Oil filter
All Oils and Coolant
If I've missed anything please add
Ben Socratous
Iv'e started to put my interior back together!!!
Monday, July 31, 2006 - 10:02 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All these people wanting to know about their 100k service, HA, I'm 4600km off my 200K service!!! Water pump and timing belt were done under waranty at 150k though so shouldn't be that pricey, I hope...
Damien Barnes
sa
TT JZZ30
Tuesday, August 01, 2006 - 10:37 am, by:  Damien Barnes (Barned01) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I posted a thread for this on toymods a couple of months ago to start gathering the bits and pieces
here is the thread:
http://www.toymods.net/forums/showthread.php?t=3514
here is the parts i have/need to gather.
quote from me from toymods:
To start off I assume i need:
timing belt 13568-49025
water pump (1610049846 )
spark plugs ngk bkr6e
oil I am using Shell Ultra 5w/50 i think
oil filter 90915-20003 (or 90915-20001)
transmission fluid dexron III (or toyota type IV)
timing belt tensioner (1350546020)
crankshaft seal (not necessary) (9031146001)
camshaft sealx2 (not necessary) (9031138041)
fuel filter (Need Part number)
thermostat (Need Part number)
coolant standard toyota red coolant 4L topup with demineralised water
/end quote from me from toymods
I haven't done the service for the car yet (it is on 98000 k's) and i still need to gather a couple of things before i can do it.
Neil griffiths is able to supply a timing belt and bearing for a good price too.
and there should be a fair amount of info lying around on this forum already
Michael Sinay
Saturday, December 01, 2007 - 01:23 pm, by:  Michael Sinay (Mikey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are there any bearings that should be replaced as well?
Michael Keen
soarer tt
Reg: 10-2007
Monday, December 03, 2007 - 08:27 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damien Barnes wrote on Tuesday, August 01, 2006 - 10:37 am:
here is the thread:
do we know if them part numbers are correct? if so i'm going to use it and go purchase them thios week. i guess oil and coolant is personal choice i'm going to use komatsu super coolant..
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Monday, December 03, 2007 - 10:37 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
FFS use toyota coolant!!! My mate runs a radiator shop that is sponsored by tectaloy and even then he still sings the high praise for the toyota coolant! Not to mention that if you are using an oem water pump, the waranty goes out the window if you use aftermarket coolant.
Charlie Ters
Reg: 01-2007
Tuesday, December 04, 2007 - 12:17 am, by:  Charlie Ters (Ul05st) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
useless info:
i heard coolant is made by only 2 places in Australia--companies only add crap to it later on..... (useless fact i found out).....just like oil, only Mobil and one other company supply the oil bases to the world....everyone else does their own thing to it... (thats why i think Mobil 1 is king )...
Mike Thomas
AB
JZZ30 Soarer TT
Thursday, March 06, 2008 - 02:49 pm, by:  Mike Thomas (Petcanizzle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
whats average cost on a water pump?
Luke Yates
VVTi 1jz
Reg: 01-2007
Thursday, March 06, 2008 - 10:52 pm, by:  Luke Yates (Trd662) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HARMONIC BALANCER !!! Check it !
Sorry for the caps but i can't stress this enough. Mine was about to fall apart when i did mine.
Shane Haverkamp
soarer TT
Reg: 10-2007
Thursday, June 26, 2008 - 06:05 pm, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi everyone. i have a 92 TT and i'm coming up to my 100,000k service as well. i'm wondering if there's anything i should be looking at turbo wise?
as far as i can tell they dont blow any smoke, and i still get a good 10 psi during boost (according to my gauge)
should i consider also getting my injectors cleaned as well? or would a bottle of the pour in stuff suffice?
Back in AUS ! WOO !
XTR T-66
Thursday, June 26, 2008 - 07:44 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i probably would not bother with pulling your injectors out just to clean them unless they have been giving you dramas.
Sure run a bottle of cleaner through it... cant hurt.
I usully use some sludge remover stuff that i add to the engine oil before a service, so when it drains it apparently takes most the crap with it.
Oil stabilisers are another favorite for many... products like "Motor Up" etc.
