  Soarer Central * Mechanical - V8 * 32 Owners..............possible useful info re: removing crank pulley. Previous Previous    Next Next
Friday, October 13, 2006 - 04:33 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Useful thread from TIF.
http://www.toyotaimportsforum.co.uk/forum/showthread.php?t=13778
Dave Hart
Waikato
UZZ32
Friday, October 13, 2006 - 05:02 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmmm!
Joanne Hawkins
Reg: 10-2006
Saturday, October 14, 2006 - 04:41 pm, by:  Joanne Hawkins (Jobear58) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks very much for the imformation...it is appreciated. Two weeks ago...the car whilst driving smelt of oil and rubber....and then died.
At first I was told it was the timing belt...and there were questions as to whether or not the valves would break fitting this. I was informed later that they would do so, and now need a full motor and motor change. I live near Coffs Harbour, so I'm afraid that Sydney is just not convenient for me....and I will check out all that has been advised. Thanks again.....Jobear58
JunkFilterer
Saturday, October 14, 2006 - 06:31 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Glad you mentioned that, I was curious as to why you might need a new engine.
Soarer V8's are non interference which means that if the belt breaks, then engine just stops, no extra damage is done, the valves will NOT hit the pistons and bend or break.
About the only time I have heard of people needing to replace the engine is if they lose all the coolant and cook it.
Definitely get another reliable mechanic to check it out for you.
It's pretty much the same engine as used in the Lexus LS-400 so anyone with experience of those should know what they are talking about.
Good luck! :-)
Anish Varsani
V8 UZZ30
Saturday, October 14, 2006 - 06:49 pm, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The pulley bolt will come off using a rattle gun. Depending on if it's siezed or not, it might even come off without having to jam the flywheel to stop movement.
Paul Drane
Saturday, October 14, 2006 - 11:06 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lew had a V8 in his workshop a while back that had broke a timing belt, and that bent a few valves.
JunkFilterer
Sunday, October 15, 2006 - 12:56 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul, Scotty has a spare 1UZFE and can spin the crank and cams without any problems.
There was also a broken belt (and the mess) well documented on TIF - no interference problems.
http://www.toyotaimportsforum.co.uk/forum/showthread.php?s=45b4e7ed1c715beb225214df2b067e75&threadid =7030
However, it's possible that the later V8's (95 onwards?) with higher compression may have interference issues.
Sunday, October 15, 2006 - 09:18 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Sunday, October 15, 2006 - 12:56 am:
That is what Neil told me Peter.........it's ONLY the pre 1994(ish!) 1UZ's that ARE non interference.
The later ones do go rattle,rattle,crash,boing!
But Joannes car, being a 92 model will be fine
Paul Drane
Sunday, October 15, 2006 - 01:19 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK no worries,
always willing to learn.
Monday, October 16, 2006 - 02:48 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Sunday, October 15, 2006 - 04:44 pm:
What actually happens in that situation Neil?
You make phone calls to your nearest friendly 2nd.hand 1UZ supplier
Pretty much: Valves get bent outa shape, pistons gain added indent features, and generally the whole thing turns to bollocks in a heart beat, and even more so if ewe is pulling like, 6500rpm at the time of BOING!
JunkFilterer
Monday, October 16, 2006 - 06:50 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK, but what I don't understand, is that if the engine is non-interference, and the cams and/or crank can be turned independently with no contact (as Peter Scott has done), how can jumping a tooth cause interference to happen?
Lew Radbourn
jzz30 ute / uzz30/ 2 X uzz31
Monday, October 16, 2006 - 06:57 pm, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yer i often wonder about people saying the 1uz will not bend valves if the belt breaks.
i wonder how my valves got bent then .
suppose it could have sucked a rock in or some thing stupid like that.
i did the same thing Peter and tried to turn the crank over and it locked up every time (with belt off)
JunkFilterer
Monday, October 16, 2006 - 07:02 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What year was it Lew?
Lew Radbourn
Monday, October 16, 2006 - 07:44 pm, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
92model
icould do with a bit more work
so guys don't do the cam belts toyota don't know what thay are taking about.hehehehehe
JunkFilterer
Tuesday, October 17, 2006 - 12:10 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK, thanks for that Lew. My belts should be getting done soon, I will see if we can do a rotation test just out of curiosity.
