Tuesday, November 21, 2006 - 11:31 am, by: Mike Beck(Gold_40gt)
Theres no problem with my power steering, its not leaking etc, in fact it was repaired a couple of years ago (Just thought Id say that before you come to a conclusion)
However since Ive had it Ive noticed its a tad stiffer than all the other soarers Ive driven, they had very light steering. Mines okay at low speeds but does get stiffer on the Highway which I realise its ment to do but Im what Im asking is there some way to make the steering less stiff overall, something to adjust? Its not bigge but Id like it to be a bit more easy to use
Through reading the other posts around the forum perhaps theres a problem with the PS ecu? However I couldnt see why as it works fine at low and high speeds.
Wednesday, November 22, 2006 - 10:33 am, by: Anish Varsani(Yomama)
Power steering ECU? Didn't know such thing existed on the soarer.
Mike check your wheel alignment against factory spec (assuming all bushes are in good condition). Factory spec will give you a very light feel. If it's setup for more agressive cornering, it might feel a bit heavier.
