how much at the most should it cost to replace the standard two cats with aftermarket ones e.g just for labour and own cats supplied. The walker units have the pipe on both ends that require flanges to be made up to fit upto your existing system so you dont need to weld straight onto the cats themselves like neils or im wrong
Saturday, April 07, 2007 - 01:37 pm, by: David Vaughan(Davidv)
http://www.rushimports.com.au/ except that the web site has yet to be fixed after it was hacked recently. Search for Neil Griffiths or username aussiesc and write to him or ring 02 6284 3111 during business hours.
Now that I have helped you, I will turn to something more serious. Keegan, there is this Search facility reached by a button at the top of the page. You are told about it in the FAQ, and in the Rules and Policy section. You are also told there to read around before asking questions. Had you done so, you would have found not only the answer to your question above but also plenty of cases of newbies being reminded to use Search. So, how about you try that yourself before your next question?
Dan McColl Goo Roo Victoria Active V8 and a Factory Manual XF.
