  Soarer Central * Mechanical - V8 * 2jz in uzz31 Previous Previous    Next Next
Andy Xie
Uzz31
Thursday, April 12, 2007 - 10:58 am, by:  Andy Xie (Bov) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
has anyone ever try to put 2jz in the z31? i know that with the 1jz you can bolt the 2jz with original engine mount. running with original ECU.
but if i get the 1jz engine mount, will it fit the 1uz space?
just wondering, cost too much to increase hp on my current set up.
Thursday, April 12, 2007 - 08:05 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are you talking about a Naturally Aspirated engine or Turbocharged?
You can buy a 2JZGE Jzz31 that came from the factory.
Phil Gibson
'94 black/black UZZ31
Thursday, April 12, 2007 - 09:48 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
With what it would cost to put a 2JZ-GTE in a V8 Soarer you could twin turbo/supercharge the V8 and make more power and/or have better driveability than the 2JZ...
Andy Xie
Uzz31
Monday, April 16, 2007 - 12:35 pm, by:  Andy Xie (Bov) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i already got a b8 with 2 t25, but the problem is when i try to upgrade the turbo, i have the limit space , mind you, i have heating problem with the current set up.
if i want to have a single turbo then i need a to change all the piping again.
its hard to get a jzz31 with na 2jz, or too pricy
