  Soarer Central * Mechanical - V8 * Some V8 TT questions, Forged bottem end, boosting, etc Previous Previous    Next Next
Open in new windowArchive through April 23, 2007Miles Baker25
Tuesday, April 24, 2007 - 08:11 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Miles , if your talking about American people, enough said
Hehehehehehe.
I actually quite like the viper, its up there in my top 5!
Lew Radbourn
jzs147 92 / 95 jzz31 98' / jzz30 ute92' / uzz30 93'/ 2 X uzz31 92' s
Tuesday, April 24, 2007 - 10:52 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
BUT,
Who on here has the $$ to spend on decompression !!!!!
Well i don't really have the money
BUT i have committed so much in, so now there is no turning back.
"ON WARDS we shall strive and there WILL be no turning back"hahahaha
BIG BIG money pit.
USDM 2J camshafts installed!
Tuesday, April 24, 2007 - 11:25 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lew is it because they're not off the shelf?
You getting custom pistons made up?
Shouldn't be that much more expensive for custom ones (not that i know, just speculating), they're not cast anyway so the tooling costs are equivalent to a little CAD re-adjustment.
Anything else i'm failing to consider, apart from labour, bolt kit etc. Thought you'd only be replacing the pistons.
Lew Radbourn
Tuesday, April 24, 2007 - 11:41 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cihan;
about 2 yrs ago David Phan did a bulk buy of de compressed pistons from America i was one of the guys that bought a set
BUT that is not the end of what has to be done to do it properly.
the only thing that is left un touched is the out side of the block.
cranks has been ground to suit rods ,nitrided and re balanced.
bores have been done
heads have been done
Valves also
valve springs,metal head gaskets and the list goes on and on and on.
so far i recon about $5500 has been spent with out the cost of the machining so far then the assembly
I personally arn't assembling the engine i have a good mate up here that builds Mopar race engines so i have left it up to him.
So possibly around $10,000 and the bottom end will be assembled and the heads sitting on.
then there is all the external parts to go on possibly another 10-12K for all that.
So there for having a de-compressed motor and trying to force a crap load of air into it is a very expensive pass time.
Mind you it is being built to handle 1200 Hp
* not saying it will get there(1200Hp)
But it will handle that kind of power.
i am expecting around 600-700 on a good day hehehe
Tuesday, April 24, 2007 - 06:39 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lew,
I already have 2160Mw ")
Active V8 and a Factory Manual XF.
Wednesday, April 25, 2007 - 12:41 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think you mean mW, Grampa. :-)
Lew Radbourn
Wednesday, April 25, 2007 - 07:52 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WELL i HAVE.............this big HAHAHAHAHA
i take that is milli; Neil
Wednesday, April 25, 2007 - 11:26 am, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well Milli Watts sounds better than Killi Watts :-)
hahahahaha
Now I see what you were thinkin about Lewie.
Wednesday, April 25, 2007 - 01:23 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And I think it's 216000000 mW. Sounds even better.
Or 0.216 MW
Or 216000 W
Phil Gibson
'94 black/black UZZ31
Wednesday, April 25, 2007 - 02:53 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh well i have 50 million MEGAJOULES
$50 ono
Wednesday, April 25, 2007 - 07:23 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1.21 Giggawatts Will work for the Time Machine Driven by Dr Emmitt Brown .. Hahahaha
Lew Radbourn
Thursday, April 26, 2007 - 07:07 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil.HAHAHAHAHAHAHAHA
yer that was the only pic i could find that had its hands and arms wide apart.
