Thursday, June 07, 2007 - 03:56 pm, by: Tai Johnsen(Privatejohnsen)
Hi Neil,
I know you've had yours on for a while, just wondering how you got around some of the dash errors.
Is there a way to stop the TRC from functioning without error messages?
If the TRC OFF bulb is illuminated on the dash, is there any chance at all that the TRC throttle body can move or change anything? (pushing the TRAC button on the centre console does not remove the light)
Removal of the TRC fuse has an even more annoying dash error..
I also have the "brake system" warning which i have been told may be intertwined with the TRC light.
Cruise control stopped working too..
Any info would be appreciated.
TJ
Neil Griffiths Trader NSW I have a Cadillac and a Supercharged Manual V8
Thursday, June 07, 2007 - 08:47 pm, by: Tai Johnsen(Privatejohnsen)
*update* mods? do tell
Unique to me because i have traction control and ABS and your car didn't?
Yeah, that's what i don't understand, because i have only removed what was necessary from the factory ECU.. Nothing really to do with the brake, cruise or traction control systems that i know of..
Oh well, it was worth a shot.. Thanks mate.
TJ
Thursday, June 07, 2007 - 09:12 pm, by: Neil Griffiths(Aussiesc)
I dont have TRAC....YEAH
You MAY have tapped into the Trac wire on the ECU, Because it is incorperated with the TPS setup. Look VERY hard at this part of your wiring diagram Tai. For the cruise control, I would say you have interferred with 1 of the speed signal wires.
Sunday, June 10, 2007 - 05:31 pm, by: Tai Johnsen(Privatejohnsen)
Aaahh true..
Yeah, i'm going to have a good hard look at the diagram again and see whats going on.. Pretty sure all the non-engine stuff was carried through to the factory ECU where possible.
