  Soarer Central * Mechanical - V8 * Harmonic Balancer Woes - Urgent !!!! Please Help please Previous Previous    Next Next
Open in new windowArchive through August 01, 2007Jovica Galovic25
Ashley Leach
GT Limited UZZ31 V8
Wednesday, August 01, 2007 - 01:06 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok Thanks.
Give me a couple of weeks. I have a rather large tax bill I have to pay at the moment...
Tai Johnsen
UZZ31 - V8
Monday, August 06, 2007 - 09:44 am, by:  Tai Johnsen (Privatejohnsen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jovica, are you getting my emails?
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Sunday, March 15, 2009 - 10:22 am, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The same thing has happened to me
Any one able to help?
Damian Ware
UZZ32
Sunday, March 15, 2009 - 10:27 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They cant be repaired only replaced.
You can buy a new one from Toyota or Bullet cars.
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Sunday, March 15, 2009 - 10:29 am, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I was after a replacement ASAP. Seems easy enough to change.
Sunday, March 15, 2009 - 02:08 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dean Goodwin wrote on Sunday, March 15, 2009 - 10:29 am:
Might be famous last words!
Damian Ware
UZZ32
Sunday, March 15, 2009 - 09:04 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would think you could get one within 1 or 2 days from either Toyota or Bullet.
Yes it very often is famous last words.
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Wednesday, March 18, 2009 - 03:51 pm, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The harmonic balancer actually was quite easy enough to change, put the extended breaker bar against the battery and cranked the engine once and the nut cracked straight away!
Friday, March 20, 2009 - 08:42 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Against the BATTERY! WTF???
Do NOT put the breaker bar against the battery, remove the undercowling from the car and place it against the ground. The torque from the starter could easily crack a battery open and cause acid to leak all over the place. Hell when I did mine the breaker bar lifed the car off the ground and put a small pit in the concrete floor of the garage!
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Friday, March 20, 2009 - 09:16 am, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I must of been lucky?
Dave Rose
wa
uzz31 v8
Friday, March 20, 2009 - 11:50 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Always try and use a impact gun, as the bar thing really pulls the passinger side engine mount.
An old mount will rip apart for sure.
