  Soarer Central * Mechanical - V8 * V8 Auto Trans fluid level high? Previous Previous    Next Next
Tahmid Sanjari
Soarer V8
Reg: 07-2007
Sunday, September 02, 2007 - 10:57 pm, by:  Tahmid Sanjari (Rednchrome) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys the auto trans fluid level dipper always shows level way past all the indents. There are the 2 indents (min-lower, max-higher) for the cold reading and higher up there are the 2 indents for hot reading. I have always pulled the dipper out in a cold engine first thing in the morning and the level shows way above the hot max dent. Is this ok? If not how do I drain a bit? Is a flush relatively easy task?
JunkFilterer
Monday, September 03, 2007 - 04:44 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did you have the engine running when you check it?
Tahmid Sanjari
Soarer V8
Reg: 07-2007
Tuesday, September 04, 2007 - 10:55 pm, by:  Tahmid Sanjari (Rednchrome) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Peter for the hint. Yeah the level is all good when the engine is running. Didnt know that it does that.
JunkFilterer
Wednesday, September 05, 2007 - 08:03 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Excellent! That's what SC is all about.
