  Soarer Central * Mechanical - V8 * New to the scene Previous Previous    Next Next
Daniel Renahan
Reg: 12-2007
Friday, December 14, 2007 - 12:51 pm, by:  Daniel Renahan (Liasis35) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good morning everyone!! first i would like to introduce myself as Dan.. Im the proud owner of a 91 Lexus sc400 gt-l with 165k and im already in love lol. I have a few problems though i drove it from Brisbane to cairns without a hiccup but now i have the Engine Electrical and Radiator coolant level lights on... the radiator is full of fluid and the engine is running fine except for a rattle inside the middle cat.. any ideas?? also i have a greenish oily spill on the ground in the morning after its been sitting for the night... Apart from that these cars are amasing for there age!!!
Darryn Dewar
Gisborne
UZZ30 Soarer
Friday, December 14, 2007 - 01:02 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Running Diagnostics as per
http://soarercentral.com/sc-forum/messages/1113/1113.html will give us a better idea of the Engine Electrical problem.
JunkFilterer
Friday, December 14, 2007 - 02:43 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The green stuff could in fact be coolant.
Celsior UCF11 V8
Friday, December 14, 2007 - 09:24 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel Renahan wrote on Friday, December 14, 2007 - 12:51 pm:
Could also be Refrigerant, mine has a green die, doesnt leak bad but my Mechanic noticed it around the unit that had dried..
Daniel Renahan
Reg: 12-2007
Saturday, December 15, 2007 - 03:56 pm, by:  Daniel Renahan (Liasis35) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks for the replies!! i have tried running the diagnostic inside the car but unable to get it to work...
Daniel Renahan
Reg: 12-2007
Wednesday, December 19, 2007 - 06:23 pm, by:  Daniel Renahan (Liasis35) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok i got the Diagnostic to work and everything is working fine.. but i still getting the error appearing on the screen.. plus on warm up i have the handbrake on light come on and stay until i turn the car off, anything else i an check??
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Thursday, December 20, 2007 - 12:28 pm, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel, are you also getting a "Brake System" warning and "ABS" warning on the dash? Also, if your car has traction control, does this automatically turn off when you get the brake system warning and hand brake light appearing?
There are a list of warnings here
http://soarercentral.com/scforum/messages/1113/74535.html?1150010852
My car had a similar problem, 91 V8 Limited. Doug from sports and luxury fixed it up, i can give you a list of the parts he changed to fix it up.
Daniel Renahan
Reg: 12-2007
Thursday, December 20, 2007 - 04:10 pm, by:  Daniel Renahan (Liasis35) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Dean, No i have no brake system warning light on just my TRC OFF light... While im here how do i turn Traction control back on?? i see the TRC OFF button but no on button...
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Friday, December 21, 2007 - 09:28 am, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The traction control OFF button is also the traction control ON button. But if your car is anything like mine was, your traction control will not come back on.
My car needed a Toyota Soarer TRC/brake switch ($102.00) and a second hand ABS TRC ECU ($380.00) to fix the problem. I'd probably start with the TRC/brake switch and then take it from there. I have no idea where these parts are, sorry i can't be of anymore help.
