  Soarer Central * Mechanical - V8 * Fitting Perfect Power SMT6. Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Thursday, February 14, 2008 - 07:18 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, the first guy I took it to with a dyno didn't want to know about it. The second guy said he would give it a go.
Armed with all the info I could accumulate on it's installation, I left it with him for the day.
He rings me after a couple of hours and says he can't work it out as there are 4 plugs (not 3) as shown in the wiring diagram from Perfect Power.
My car is a 95 model (which is supposed to be covered), so I guess this is the difference. No matter how hard I try to find the right information for my car to wire up the SMT6 I cannot find it.
Can anyone on this site help out?
Tai Johnsen
UZZ31 - V8
Thursday, February 14, 2008 - 07:38 pm, by:  Tai Johnsen (Privatejohnsen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mike..
Welcome to the world of late 94-95 factory ECU :-)
I had the same problem when I installed my adaptronic.
http://soarercentral.com/sc-forum/messages/282/159949.html
It has more plugs than the older ones.
The old ones have 3 x 40 pin plugs.. Ours have 4... Like this... (pic from my car)
I have a file on my PC somewhere which I used to install mine.
It should have all of the connections you need + more.
Shoot me a PM if you want it and I'll try and to find it and send it to you.
Maybe it should be posted on the website somewhere?
Wafi Cheebo
Reg: 09-2006
Friday, February 15, 2008 - 04:30 pm, by:  Wafi Cheebo (Wafi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just a simple question for you Mike, where did you buy this SMT6 from? And how much does it cost? I am thinking of getting one myself
Mike Bradberry
V8 UnLimited
Friday, February 15, 2008 - 07:28 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Wafi, I bought it from a club member probably nearly a year ago. He only fitted it for a short time I believe as he upgraded.
New they are around $450.00, I can't remember what I paid, but it was under $300.00.
I might consider selling in fact as I can't find anyone to fit it to my late model.
Tai Johnsen
UZZ31 - V8
Friday, February 15, 2008 - 10:50 pm, by:  Tai Johnsen (Privatejohnsen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi again Mike,
Have faith.... :-) the file will help you out. (still searching for it)
I was ready to give up my stand alone when i couldn't find the wiring information.
All you really need is the right information. It took me a full weekend, but it was running by Sunday arvo.
I'm sure you could even have a crack yourself if you can wield a soldering iron and read a map :-)
If you are really struggling to find someone I could probably help you out too..
TJ
Mike Bradberry
V8 UnLimited
Friday, February 15, 2008 - 11:08 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Tai, I would have no trouble with soldering but would shy away from the actual tuning. This is why I sought out a dyno person to do the tune.
However, I am not discounting your offer. Once I get hold of the info I need I might be in touch.
Cheers.
Wafi Cheebo
Reg: 09-2006
Saturday, February 16, 2008 - 08:55 am, by:  Wafi Cheebo (Wafi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mike,
Do you have a mobile phone number I can contact you chon by any ance, I might consider buying it of you, how much would you sell it for?
I have a 1991 model so it will fit
Mike Bradberry
V8 UnLimited
Saturday, February 16, 2008 - 09:15 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wafi, PM sent.
