Friday, July 04, 2008 - 10:12 am, by: Jovica Galovic(Gryphn)
Hi All,
Im loosing coolant about 750ML over a 10 day period. There is also a slight knocking noise at the front of the engine at idle goes away at anything above 1000rpm.
Does this sound like the water pump or something more sinister.
Ill be doing the timing belt and what's associated in 2 weeks so I'm wandering if i should just buy the pump as well. Is there anything else I should be changing ?
Also my rear seal is now weeping :-/. What's the approx cost of having it changed and the trans flushed/serviced
