Thursday, July 24, 2008 - 04:21 pm, by: Darryn Dewar(Mrphreak)
There's a good chance the top gun leads will be the wrong lengths, they may have finally fixed the problem by now though......A quick search will give you an idea of the problems people have had
Thursday, July 24, 2008 - 07:31 pm, by: Rich O'neil(Kiwiinaus)
Where to start , no disrespect for top gun or eagle but they are not in the same park . These leads are probably better than genuine , double silicon spiral leads with S/S fittings and the kit comes with 3 coil leads so it can do LS/Celsior and Soarer's . Have supplied quite a few of these and fitted about 6 sets myself .These even have degree'd fittings inside the caps , no using straight fittings in angled rubber boots , even have a smear of lubricant on the inside end of the cap that goes over the plug !! If you want cap,rotors and NGK Platinum plugs also let me know , plugs come in at $9.80 each .
Mike Beck Goo Roo New Zealand Soarer Limited UZZ31 & Soarer 3.0GT JZZ31
Saturday, July 26, 2008 - 07:35 pm, by: Ben Kelly(Ace)
Rich I'd also like a set of leads. From your post it sounds as though they fit a v8 without modification and are at least as good as the genuine part(?)Can you please give me postage costs, your details and delivery time. Thanks
