  Soarer Central * Mechanical - V8 * If you think getting a K&N air filter is a good idea then don't. Previous Previous    Next Next
Open in new windowArchive through November 22, 2010Tom Brookes25
E36 Coupe
Monday, November 22, 2010 - 04:01 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes I did one on mine, not really sure if it made much performance difference, but it sounded sportier for sure.
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Monday, November 22, 2010 - 06:32 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I want to put a ram air induction from that same panel you've used, but obviously would need a FMIC or else the side intercooler isn't going to get any decent air.
I wouldn't have made it with tubes, instead cut up some cardboard cut to shape and then fibreglass when it suits.
It's a big ish project and something for my future.
On a NA 1.5L charade I had a tube like yours from my frontbar ram air induction into my panel filtered airbox and used a resister in the intake air temp sensor line so it read about 5c colder than it really was so that it was a slight bit more fuelly all throughout.
I easily gained a lot of power by removing the stock (incredibly restrictive) and then a bit more as i picked up speed. It really improved throttle response and top end power. It became a little asthmatic when previously driving it. The baffles and small intake kept the engine quiet.
I don't think that's such a huge problem or restriction on the jzz31. The design of the car is totally different.
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Tuesday, November 23, 2010 - 03:00 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So Seems like the Pods on the V8's don't do any good, is it to do with the airflow being more smooth with the BFI?
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Tuesday, November 23, 2010 - 06:13 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well boris, I don't know but I have a theory.
Everyone grossly underrates how good the stock toyota panel filter flows.
As for how it runs worse? I'm even more stumped.
Dave Rose
wa
uzz31 v8
Tuesday, November 23, 2010 - 08:09 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All the tests are on Planet Soarer ,the ram scoop did not fair very well.
