Saturday, August 30, 2008 - 09:37 pm, by: Sean Routledge(Stircrazy)
I've tried to find something about it but can't find anything exact so here goes...
I picked up the car today and have driven it nonstop till around now. Not sure if the noise was audible earlier but now when i rev the car, or drive it has a constant whining noise that gets louder as the revs get higher? Not sure if it's normal or not but it doesn't do it on idle, just when revs are applied. Sorta sound like a quiet supercharger (i wish).
Not sure where exactly it's coming from but i'm pretty certain it's the drivers side?
If anyone could help it would be much appreciated. Cheers Sean
Sunday, August 31, 2008 - 07:12 am, by: Sean Routledge(Stircrazy)
that's what i first thought after reading other posts, but it seems to have nothing to do with me steering or turning the wheel? Where exactly is the power steering pump and where do i check the power steering fluid?
Sunday, August 31, 2008 - 10:24 am, by: Sean Routledge(Stircrazy)
may be coming from there, if it was power steering, wouldn't the noise get worse when turning the wheel? One more thing i've just noticed is every so often, there seems to be a noise that lasts only around 3-4secs, sound like something engaging then switching off. I think it is either the brakes or steering? What could that be?
Monday, September 01, 2008 - 11:08 am, by: Dave Rose(Sand_groper)
Sean try taking the acc belt off for a moment see if it goes?...dont worry if you get a bong and a message on speedo.....if it goes it could be idle or tensioner bearing
Monday, June 01, 2009 - 07:13 am, by: Mark Wright(Lexp48)
can anyone tell me what the whining noise is everytime I turn the ingnition on? it goes once the engine has started, sound like the noise you would get from a fuel pump although the noise seems to be coming from the engine bay!
