  Soarer Central * Mechanical - V8 * Got UniChip installed.. Dyno analysis Previous Previous    Next Next
Mark Ribbans
UZZ-031 V8, 1972 Mazda RX2 Coupe, TE Gemmy
Sunday, October 26, 2008 - 09:44 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Guys,
I finally got around to getting a UniChip installed during the week. I got a roughly 10% improvement which was exactly what i was expecting, so I'm very happy. Car performs noticeably better right across the range.
Unfortunately I didn't get a chance to speak the tuner so I was wondering if anyone could help decipher my dyno graphs. I'm not really sure how to read the air fuel ratio. I *think* it says that pre UniChip (top line) it was running rich at around 10:1 under full load and that now it is running a bit leaner at a pretty consistent 13:1 ??
Engine mods are the 'big three': BFI, Headers/Exhaust and now the UniChip.
Engine has had leads & plugs, belts, dizzy rotors, bearings, plugs replaced in last year or two.
During the dyno run the car had dirty air filter (got a new one now) and exhaust leak where extractor bolts to head (think I've blown the gasket out) which probably robbed a kW or two.
All up, this is definitely a recommended upgrade..
Matt Petersen
NA
Reg: 01-2008
Monday, October 27, 2008 - 04:58 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My dyno run a month or so ago got me 139kw with no mods and the AFR was just over 10:1 at WOT.
What was the total cost installed and tuned?
Matt.
Soarer Limited UZZ31 V8
Monday, October 27, 2008 - 07:56 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow excellent news Mark!
I want a uni chip now that Ive decided to get headers!
Scott Casey
soarer v8
Reg: 02-2008
Monday, October 27, 2008 - 11:47 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
would the AFR at 13 ping on hot days with wide open throttle???
did the tuner change any of the timing??
Mark Ribbans
Monday, October 27, 2008 - 12:12 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Total cost was $350 fitted and tuned (plus cost of the 2nd hand UniChip - thanks Mike B. Oh and sorry it's not for sale :-) )
AFR at 13 is about where it should be for optimum performance (according to the reading I've done since). I hope it doesn't ping!
Timing was advanced 6 degrees when Peter Scott got his done at the same place a few years ago, but I'm not sure if this was done or not since I didn't speak to the tuner. However, since this chip is the exact same one used in Pete's car back then it may have been left as is? Think Imight call the tuner for a chat.
Full article is here:
http://www.planetsoarer.com/unichip/unichip.htm
David Bailey
Mz20 3.0GT
Reg: 10-2008
Monday, October 27, 2008 - 06:46 pm, by:  David Bailey (Mznut) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats great value!
mmm i wonder if they make one for an MZ20?
Mark Ribbans
Monday, October 27, 2008 - 08:24 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is a quick video of how it sounds:
http://www.youtube.com/watch?v=AXexEnBOwdg
Ashley Leach
Supercharged GT Limited UZZ31 V8
Tuesday, October 28, 2008 - 11:16 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks good. I'm going to head there at the end of the week to see if they can tune my adaptronics.
157kw... Damn, I wish I had my last dyno graph on me.
Wednesday, October 29, 2008 - 04:53 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Afr's in the low to mid 13's is Optimal for Naturally aspirated cars !
Sounds nice mate, and nice power increase too !
Mark Ribbans
Friday, October 31, 2008 - 10:52 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I put a vid up of my Soarer doing 40-100Kph if anyone is interested.
40Kph=double kickdown..
http://youtube.com/watch?v=E70mFm9kbKM
Mark Ribbans
Friday, October 31, 2008 - 10:57 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Ash how long have you had a puffer? Hmm.. would love to go for a spin and feel the difference another 70Kw makes. You ever near the CBD? I never thought I'd go for forced induction, but I'm already used to the extra power and i want MORE! Actually, Morpowa is 5 mins from my place if you wanna drop past after your tune up!
Ashley Leach
Saturday, November 01, 2008 - 02:03 am, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm I don't know... 4 months or something.
An extra 70rwkw just makes for mad wheel spin action. It's actually pretty bad when you just stamp your foot on the floor as the wheels don't grip until 3rd gear with the Torsen.
Not really near the CBD much any more but I'm at Mawson Lakes most of the time. Getting tuned at Fours N More on Tuesday night, the guy knows the adaptronics so we will see how it goes. Not really looking for more KW, just need to sort out a few gremlins that are in the tune.
Once you go FI you still want more, it's like a disease or something. I'd love to get a twin screw on there if I could fit it under the bonnet. But it look so pretty now all shined up, I don't think I could part with the Yella Terra.
I'll do you a deal. Take me a for a spin and I'll take you when it's all done.
Mark Ribbans
Monday, November 03, 2008 - 01:31 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So you get wheel spin all the way to 3rd AND you have an LSD?? Wow.. OK let me know once you're all tuned up and we'll compare rides.. :-)
Ashley Leach
Monday, November 03, 2008 - 02:52 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Only if I plant it. :-)
1st and is a Nanna Volvo take off all the time though.
Car is going in tomorrow arvo. Hopefully have it back on thursday.
