  Soarer Central * Mechanical - V8 * Mystery cranking problem please help Previous Previous    Next Next
Adam Brockman
W.A
GT V8
Reg: 11-2008
Friday, November 07, 2008 - 06:32 pm, by:  Adam Brockman (Ab89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey just looking for some advice, my car not starting at the moment, she cranks but theres no final start, so there not flat battery or anything there fuel in the tank to create spark but still nothing ? i injected some fuel into the block to see if i had a fuel pump problem that still did't do anything, the RAC dude said he thinks he i have a issue with my Crank sensor? have no clue were it is or if that really is the problem, the RAC dude looked a little confused and said he dont no much about these any help any ideas,
i would love to get her started up and working for the Show and shine this sunday
Soarer Limited UZZ31 V8
Friday, November 07, 2008 - 08:05 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I do recall the crank sensors can play up after a while, could well be related to that?
Friday, November 07, 2008 - 08:14 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would start with the Fuel pump ECU bypass... In the diagnostics box you bridge FP and B+. Also check the EFI fuses in the fuse box.
Dave Rose
wa
uzz31 v8
Friday, November 07, 2008 - 09:05 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check the wiring ....1 crank sensor,bottom just behind bottom pulley...2 cam angle sensors the wires at the front of engine half way up ..make sure the belt has not worn any wiring.
Dave Rose
wa
uzz31 v8
Friday, November 07, 2008 - 09:32 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Drane
Saturday, November 08, 2008 - 04:28 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It could be a faulty igniter.
Brett Harrison
Sunday, November 09, 2008 - 12:41 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just a guess Paul ?
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Monday, November 10, 2008 - 01:07 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
One of the cam sensor's wiring sits very close to the belt and it has been known to wear through.
A faulty ignitor will not stop it from starting, unless you have 2 faulty ignitors. Likewise with coils and leads.
FP ECU bypass is the first place to start.
Dave Rose
wa
uzz31 v8
Tuesday, November 11, 2008 - 09:42 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Adam are you still with us??
Paul Drane
Tuesday, November 11, 2008 - 11:28 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Turns out mine wasnt igniters at all Brett.
