Sunday, December 14, 2008 - 11:26 am, by: Vinny Ozorio(Fruitloop)
Arrrrrr... New problem.!! The fan seems to want to stay at a "low flow" rate.. that is prior to this morning when the A/C was selected on the fan "used" to go to a fast rate,now it doesn't change speed at all.The only thing that has been changed lately is a new Radiator fitted..Any idea's ???
Monday, December 15, 2008 - 10:22 am, by: Vinny Ozorio(Fruitloop)
Ok looks like I've "stumbled" across a "new" problem.I did what Peter N suggested (Turn the temp knob to full cold)and the fan runs at full speed.Does any-one have a wiring diagram and any idea's where the temp sensors are that determine when the fan turns on ?? Cheers
Monday, December 15, 2008 - 03:38 pm, by: Vinny Ozorio(Fruitloop)
MWWAAHHH Peter..thank you...Looks like another day of being inverted like a fruit bat looking behind the dash...The one on the nose cone (lower intake) looks ok (that is nothing loose)but other then changing it is there a test figure for impedance ? again thank you !!
Wednesday, December 17, 2008 - 04:36 pm, by: Vinny Ozorio(Fruitloop)
It was the hydraulic fan..Its all sorted out now.seems that a bit of contact cleaner sorted out the sensor problem .(and I learned a little bit more about the wiring ECU etc etc )
