  Soarer Central * Mechanical - V8 * Master Brake Cylinder Unit TRC Previous Previous    Next Next
Justin Cook
Sunday, December 14, 2008 - 04:50 pm, by:  Justin Cook (Justin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
Tried searching found a little info., but not exactly what I needed.
My parents have an Aristo with a leaking TRC brake master unit...pretty sure nitrogen is low too etc etc.
Is there someone who can service these I mean the master cylinder itself? I read maybe Peter Taplin does this? But I am not sure if he only does the nitrogen canister and not the master brake cylinder?
Otherwise going to have to find an overpriced second hand unit, and hope it doesn't meet the same fate as this one!
David Janiec
Soarer 4.0GT-L UZZ31
Sunday, December 14, 2008 - 05:39 pm, by:  David Janiec (Davidj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Although pretty unhelpful information I'll contribute what I know...
I had a thread open a while back because my master cylinder was leaking (not sure if the aristo has a different master cylinder to the UZZ31) but I took it to some specialist brake rebuilding place and they wouldn't touch it at all. I ended up buying a second hand unit and putting that in.
To be honest for someone like me who has reasonably limited automotive abilities it wasn't that hard at all - the hardest part was picking the heavy bastard up and getting it into the engine bay all lined up properly!!
Justin Cook
Sunday, December 14, 2008 - 05:57 pm, by:  Justin Cook (Justin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah yes I read your thread just after I posted this. Seems rebuilding is limited to the accumulator at a whopping $400 a pop. So anyway trying to find a good second hand unit at the moment. Hopefully the accumulator on that will be ok for now. Can't afford 300 and then another 400 :-(
David Janiec
Sunday, December 14, 2008 - 06:06 pm, by:  David Janiec (Davidj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
One little tip - I never managed to swap the accumulators off the spare (mine was better than the spare). They were on there so tight nothing worked.
What I ended up doing was pulling the pump off the plate (the plate that the accumulator screws on to) to swap them out - much easier believe me!!!
Daniel Lamont
UZZ31 V8
Reg: 06-2008
Tuesday, December 16, 2008 - 09:56 am, by:  Daniel Lamont (Dan01) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had my entire master cylinder replaced recently and for a new item from japan cost $3500 with a two year warranty because we couldn't find a second hand master cylinder.
Justin Cook
Tuesday, December 16, 2008 - 12:23 pm, by:  Justin Cook (Justin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If I had to pay that, I would just strip the bugger...that's ridiculous, for a car that you can't even sell for 7k these days :-/
Dave Hart
Waikato
UZZ32
Tuesday, December 16, 2008 - 03:03 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And the dollar/Yen exchange rate now is a lot worse.
Ahhh the joys of owning a Soarer!
David Janiec
Tuesday, December 16, 2008 - 07:49 pm, by:  David Janiec (Davidj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
GG Japan.
