Saturday, January 24, 2009 - 11:36 pm, by: Michael Webster(Mickwebs)
I have an SC400 can you repair a leaky sump with out removing the engine from the car ? It is leaking around the seal between the alloy sump and the motor.
I have tried searching but no clear answer seems to come up in the results.
Sunday, January 25, 2009 - 12:22 pm, by: Matthew Sharpe(Madmatt)
Assuming you have a UZZ30 or UZZ31 Soarer, not an SC400, then yes, you can drop the sump enough to replace the gasket in situe. No idea on an SC400, or UZZ32.
Andrew Ferres Goo Roo WA '90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
