Hello all, my apologies if this has been covered, but I wasn't able to find anything relating to this using search.
Anyway, so i noticed a hissing noise in my V8, definatly air related, coming from mid left side of engine. Turns out the T joint circled below...
Has snapped a the joint.
Was wondering if anyone knows what this hose does (and is it relating to AFM cos its been running rich recently)? Wether its safe to drive the car 30mis to Joe (need to get him to look at a leaky radiator anyway) and if not what the part number might be?
Any help appriciated.
Cheers Fitz
Andrew Ferres Goo Roo WA '90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Monday, May 04, 2009 - 11:41 am, by: Andrew Ferres(Peewee)
Oh, its safe to drive, it won't be affecting that much, but the problem is that its part of that big black intake pipe to the left. Its one cast plastic piece.
Monday, May 04, 2009 - 12:16 pm, by: Rich O'neil(Kiwiinaus)
The plastic boss around it is big enough for it to be tapped out to 1/8 gas and then you just screw a brass hose tail into it,you can get the correct size hose tail from any Autobarn. A better solution is too remove the valve on the side of the P/S pump , break off the plastic end weld it over and then screw it back in again,this will eliminate the sucking of the P/S fluid into the engine at a later date when the "O" Ring in the valve wears out. I would be suprised if you notice the difference with the idle part missing .
