Rob Rojo
Goo Roo NSW Soarer TT & UZZ31 & another UZZ31
Posts: 2436 Reg: 12-2007
| Our V8 Soarer makes a tapping noise but only when hot, on a cold start it is very quiet. I originally thought it was the shims but that would be worse when cold. I have recently changed the oil to 10w40 Mobile Semi synthetic but made no difference. Any thoughts? |
Evan Kaio
TryHard Beautiful sunny good @ rugby Wellington '91 UZZ31
Posts: 464 Reg: 01-2007
| Carbon canister maybe, mine ticks when the engine is warm. |
Rob Rojo
Posts: 2437 Reg: 12-2007
| It it quite loud and sounds like a noisy lifter but totally quiet when engine is cold. |
Adam Foster
TryHard SA uzz30
Posts: 497 Reg: 07-2005
| what about the exhaust manifold gasket leaking. some times the manifold warps under heat creating that ticking noise you hear and when its cold it returns back to normal so when the engine is cold you dont hear it. try a new gasket, if this doesnt work you might have to get the manifold depending which one machined. |
Evan Kaio
TryHard Beautiful sunny good @ rugby NZ '91 UZZ31. 92 TT
Posts: 466 Reg: 01-2007
| Rob does the tapping or ticking noise still continue after engine shut down? |
Simon Petrony
Tinkerer Collins V8
Posts: 8 Reg: 05-2009
| Yep I have the same issue. Thought it was the shims but when its cold nothing. Once it warms up it ticks like a Datsun 120Y...very annoying. |
Rob Rojo
Posts: 2477 Reg: 12-2007
| Evan, the tapping is only there when engine is running. |
Michael Jaballah
TryHard Vic UZZ31
Posts: 352 Reg: 01-2008
| carbon cannister |
Rob Rojo
Posts: 2478 Reg: 12-2007
| I am sure its not the carbon canister but I will disconnect it and try anyway. |
Adam Foster
DieHard SA uzz30
Posts: 502 Reg: 07-2005
| exhaust manifold |
Dave Rose
DieHard wa uzz31 v8
Posts: 901 Reg: 03-2007
Posts: 5218 Reg: 03-2006
| Loose or cracked exhaust manifold . When cold, no leaks, once warm and warped and crack opens, Hello ticking . |
Rob Rojo
Posts: 2493 Reg: 12-2007
| I hope that is all it is, ill be checking it tomorrow. |
Adam Foster
DieHard SA uzz30
Posts: 504 Reg: 07-2005
| the worst will be needing to get the manifold machined, they tend to warp more than crack |
Rob Rojo
Posts: 2515 Reg: 12-2007
| Had a quick look yesterday and using a bit of hose to listen to the ticking. It does sound like the exhaust is leaking and no noise coming from the Cam covers. |
Garion Gibson
Tinkerer QLD Soarer V8 GT
Posts: 84 Reg: 03-2008
| I have the same problem, quiet when cold but after a while its loud. Last month a put a set of headers on. The problem is still there... |
George Lu
TryHard vic v8
Posts: 319 Reg: 02-2006
| I get the ticking noise when i turn my engine off (when engine is hot) |
Goo Roo New Zealand 4.0GT UZZ30
Posts: 3907 Reg: 11-2005
| Contraction of metals... duh. |
Scott Casey
TryHard nsw soarer v8
Posts: 305 Reg: 02-2008
| go and listen to a flogged commodore and see if its the same "ting, ting" sound after its turned off |
Dave Rose
DieHard wa uzz31 v8
Posts: 985 Reg: 03-2007
| George its mainly the heat shelds by the cats that make the clicking. |
Sam Atash
TryHard WA UZZ31
Posts: 262 Reg: 06-2008
| Haha yea my BMW does it hell bad after i flog it down the FWY and get home, ticks for a good 10 minutes |
