Wednesday, August 19, 2009 - 04:53 pm, by: Robert Davies(Blueone)
I have a high idle problem, in park, but when I shift into gear it settles down pefectly. Happened the other night after a particularly royal caning, testing out brakes and things.
Also does anyone know what the second plug goes to that comes off the AFM...?? THE AFM is the big plug and the little one is swinging in the breeze..
Sunday, August 23, 2009 - 11:19 am, by: Dave Rose(Sand_groper)
Robert I think you need to clean the throttle body around the butterfly. it will cause your revs to alter and cause run on ,use a carb cleaner and toothbrush .good luck
Monday, August 24, 2009 - 06:46 pm, by: Robert Davies(Blueone)
Mike Beck wrote on Sunday, August 23, 2009 - 04:05 pm:
ICV problem.
Hey mate, the ICV was working fine until I changed the intake from the standard one with that big box into a polished stainless one which goes over the back of the motor to new airbox.
Monday, August 24, 2009 - 06:48 pm, by: Robert Davies(Blueone)
Dave Rose wrote on Sunday, August 23, 2009 - 11:19 am:
It actually does look to have a little corrosion in there... but the butterfly is opening and closing quite freely it would seem.
Sunday, September 06, 2009 - 05:37 am, by: Robert Davies(Blueone)
Okay checked TPS, reset ECU, and no longer have the Catalytic converter light? WTF?? Double checking vacuum leaks and there is none, I even wenty back to the entire original air intakes.... No change to the 1000-1100 idle.
Could one of the sensors in the output housing of the gearbox have anything to do with a high idle? That gear spinning one is a zero speed sensor right? Maybe it thinks its in gear, because in gear the problem disappears????????????
Monday, September 07, 2009 - 05:33 am, by: Robert Davies(Blueone)
Okay, I pulled and checked all fuses and went back over the wiring harness around the main fuse box. No change.....and I took it for a short drive and its all settled back to normal...
