  Soarer Central * Mechanical - V8 * RADIATOR LEAK, WHAT DO WE DO??? Previous Previous    Next Next
Auckland
UZZ31 Soarer
Reg: 03-2009
Monday, September 21, 2009 - 03:54 am, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys and gals my mate Mike had broken down last night from the common problem of the top of the radiator cracking.
Here's my question.... What can we do to fix it???
Can we get a JZZ series radiator to replace it (is it a strait swap and are they the same as the V8 one's)???
Can we get it welded up as its a very fine crack and only about 1 and a half inches long?
Do we just replace it with another 2nd hand radiator?
Can we replace the top of the radiator with aluminium?
Or do we get a brand new one from toyota or a custom one?
Bear in mind he is only just starting a new job and does'nt know when the next pay day is so cheap is the word for now....
Chris Ryan
UZZ30
Monday, September 21, 2009 - 06:46 am, by:  Chris Ryan (Ryzan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi James,
JZZ and UZZ radiators are different, so you can't just swap. I believe people have modified Supra radiators to fit though.
You can plastic weld it, and it would be cheap, but it would only be a temporary fix, which might be what you're after at the moment.
I bought one of these for about $300 AUD delivered from the US. They have alloy top and bottom tanks too, so no more cracking.
http://cgi.ebay.com/ebaymotors/NEW-RADIATOR-Lexus-SC400-1991-1992-1993-1994-1995-91-95_W0QQcmdZViewI temQQ_trksidZp3286Q2ec0Q2em14QQhashZitem4148728ebeQQitemZ280388341438QQptZMotorsQ5fCarQ5fTruckQ5fPar tsQ5fAccessories
Jamie Richards
St.john's
v8
Reg: 06-2009
Monday, September 21, 2009 - 10:46 am, by:  Jamie Richards (Nwb40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey had the same problem the hole top cracked straight across.Got a top made from alloy & it works great.You can plastic weld but as chris said it would be a temporary fix. best bit would be to replace top or get a fresh radiator,the one in the link chris has i have heard works pretty good.
Monday, September 21, 2009 - 11:34 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just get a new top tank fitted if the rest looks to be OK.
Auckland
UZZ31 Soarer
Reg: 03-2009
Monday, September 21, 2009 - 11:48 am, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers for your in put guys.
Jamie Richards wrote on Monday, September 21, 2009 - 10:46 am:
How long did it take for where ever you went to make it and what did it cost you?
4.0GT UZZ30
Monday, September 21, 2009 - 12:21 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Monday, September 21, 2009 - 11:34 am:
I was quite chuffed to find my UZZ30 came with a brand new one. One less thing I would have had to otherwise spent a few hundred on!
Jamie Richards
St.john's
v8
Reg: 06-2009
Sunday, September 27, 2009 - 01:30 am, by:  Jamie Richards (Nwb40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
James Johnson wrote on Monday, September 21, 2009 - 11:48 am:
It took about a day cost $150 us
Tim Uhen
V8 GT Limited
Reg: 01-2007
Sunday, September 27, 2009 - 08:48 am, by:  Tim Uhen (Zzt231) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've had the same issue with the top tank cracking. Ebay was one of the first things which I have checked in which that time there were none listed.
Toyota wanted the radiator for $1100 a new one or $150 for the top tank but I have to wait for 2 weeks for it. I had chosen the custom aluminium option as it cost me $800 for a 40mm thick version and it was made up in 4days.
