  Soarer Central * Mechanical - V8 * Strange noise Previous Previous    Next Next
Rainer Fritzsche
vvti manual
Sunday, October 11, 2009 - 10:12 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Got a strange noise coming from my UZZ31. Sounds like chain dragging........like if you forget to hook up the safety chain on a trailer. Not there all the time, just every now and then. I think it may be airbag suspension related, but I've never heard anything like it before.
Mike Bradberry
V8 UnLimited
Monday, October 12, 2009 - 08:13 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You've been too slow getting onto it and as a result you are 'dragging the chain'.
Sorry Rainer, couldn't help myself.
The only thing I could think of is a rear wheel bearing.
Jayden Ford
Reg: 08-2009
Monday, October 12, 2009 - 07:10 pm, by:  Jayden Ford (Jaybeef) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sitting in the drivers seat can you feel it vibrating or is it just a noise.
Ive got a similar sort of thing.
Rainer Fritzsche
98 vvti manual & 95 UZZ31
Monday, October 12, 2009 - 08:21 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Onya Mike......no it's not a wheel bearing.
No, no vibration Jayden, just the noise. Probably the same frequency as the compressor kicking in, hence me thinking it's suspension related. Well that, and the fact it's the first air-bag suspension car I've had with a noise I've never come across before....
Tuesday, October 13, 2009 - 09:45 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Got TRC?
Adam Foster
uzz30
Tuesday, October 13, 2009 - 06:05 pm, by:  Adam Foster (Adam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what about the diff?
Rainer Fritzsche
Tuesday, October 13, 2009 - 08:24 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Tuesday, October 13, 2009 - 09:45 am:
Got TRC?
Yes.
Adam Foster wrote on Tuesday, October 13, 2009 - 06:05 pm:
.....don't think so. There's no noise when the car is under load. Cornering or acceleration seem to have no influence at all. Just happens out of the blue every now and then.
Wednesday, October 14, 2009 - 01:56 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any chance it's related to the accumulator pump?
Do you have any idea which end of the car it's coming from?
Rainer Fritzsche
Wednesday, October 14, 2009 - 07:45 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm not familiar with the accumulator pump Peter. - Is this part of the TRC master cylinder? I'll have to do a search on this.
....sounds like it's coming from the front, though it's really hard for me to tell as I'm completely deaf in my left ear and as such can't tell direction of sound very well. I'm going for a drive with the missus a little later, so we'll see if she can tell.
Ben Dowdell
GT Limited V8
Wednesday, October 14, 2009 - 10:54 pm, by:  Ben Dowdell (Ben) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Centre bearing?? does it happen on trailing throttle or off throttle?
Thursday, October 15, 2009 - 05:17 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rainer, the accumulator provides power assistance to the brakes on TRC systems. It has a pump to keep it charged. The pump runs for a bit when you start the car, then usually runs every 2-3 pushes on the brake pedal.
More information is always good, eg when does the noise happen? If it happens at idle, then it's likely to be under the bonnet, or possibly the fuel pump, as nothing else is moving at the rear.
Peter Taplin
UZZ32 V8 Supercharged & UZZ32 V8 NA
Thursday, October 15, 2009 - 05:28 pm, by:  Peter Taplin (Mrfourwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Guys
Have to agree with Ben to a point on this one, the centre of the tailshaft has a slip joint that should be tightened to prevent backlash and the tailshaft drooping at the spline.
When this comes loose you get a noise like a low key rattle on slowing down or coast, no load type situations and it keeps getting worse.. To fix it just tighten the centre slip joint with biggest set of Stilsons or adjustable spanner you can find.
This might be the issue.
Rainer Fritzsche
Thursday, October 15, 2009 - 10:38 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Thursday, October 15, 2009 - 05:17 am:
Thanks for that Peter.
Ben / Peter, yes this sounds more likely. Drove around last night for a while with the window down and it seemed to be coming from the centre of the car. I thought at the time it might be an exhaust heat-shield, but I think Ben might be on the money. It only occurs under light or trailing throttle. Never heard it happen under any degree of load. .....have to get it to the workshop and up on the hoist.
Thanks gents
Ben Dowdell
GT Limited V8
Friday, October 16, 2009 - 12:38 pm, by:  Ben Dowdell (Ben) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
good luck mate let us know how you get on.
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Saturday, October 17, 2009 - 05:15 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can you isolate where the noise is, cos i have this at the moment and I am pretty sure it is my cat where a bit of carbon has broken loose.
Rainer Fritzsche
Saturday, October 17, 2009 - 05:53 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
.....could be Jol. Though it sounds a little different from cars I've heard with broken cats. - Need to get under there and have a look.
Dave Rose
wa
uzz31 v8
Saturday, October 17, 2009 - 06:41 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Think Jol may be on the right track, bits are in center silencer.Just give the ex a bump under the car you should hear them .
