  Soarer Central * Mechanical - V8 * Air-con Previous Previous    Next Next
Shadi Khodr
vic
v8
Friday, November 13, 2009 - 01:31 pm, by:  Shadi Khodr (Mr_sammy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys im just wondering if anyone knows a place where i can get my air-con regassed in victoria and what would be the cost
Michael Toet
Reg: 06-2009
Friday, November 13, 2009 - 01:54 pm, by:  Michael Toet (Myke31) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If it needs re-gassing you've most likely got a leak.
I got some work done the other day at SLC and I asked about this.
Your looking at $140 for a gas and dye. Then there are about 3 typical areas where they can leak from. From there the cost can vary. e.g. $200 for new front hoses (each? - can't remember) to something like $700 for rebuilt air compressor, then if multiple leaks from hoses and compressor and condensor $$$, plus re-gassing etc.
BTW: These numbers are from my leaky memory, so best to call yourself, but that was the basic breakdown of work I got.
Andrew Duaso
Reg: 02-2009
Friday, November 13, 2009 - 02:11 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i paid $260 2 weeks ago for a new hose (new, not 2nd hand) gas and dye
it's awesome... works great!
that was at a place in preston...
just look places up in the yellow pages and call a few locals
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Friday, November 13, 2009 - 02:44 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good day.
I agree with Michael, but that being said a quick gas will get you through summer..
I just had my Falcon gased today from
http://www.mideastradiators.com/ They are on rooks road nunawadding. Nice friendly blokes.
1)Cost me $135 for Gas and Dye (would be the same for soarer)
2) $200ish for new front hoses (if needed wasn't)
3) $1000 rebuild for a falcon. I'd guess a Soarer would be closer to $1500
Adam Foster
uzz30
Friday, November 13, 2009 - 09:59 pm, by:  Adam Foster (Adam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
talk to tom cousin about getting your aircon pump rebuilt if need be
Friday, November 13, 2009 - 10:58 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I replaced the a/c compressor with a new unit and upgraded to the new R134a gas at S&LC about three years ago!
Cost me $1100 all up!
Michael Toet
Reg: 06-2009
Saturday, November 14, 2009 - 04:20 pm, by:  Michael Toet (Myke31) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep Daniel, I got told $1100 for a new compressor ($700 for rebuild). Don't think that $1100 included fitting or gas, I will be double checking that when I start looking at getting aircon done. I got these numbers on Wed.
It was $400 for a new condensor.
