Michael Brown
TryHard Queensland V8 UZZ31 Limited, Ralliart Magna, Holden Camira
Posts: 251 Reg: 07-2009
| Hey just wondering what would happen if the radiator top tank was cracked ? would it cause overheating issues ? or would it just leak ? Cheers |
Posts: 11243 Reg: 11-2004
| It would just leak. However the leak would then cause over heating issues. |
Michael Brown
Posts: 252 Reg: 07-2009
| oh ok so if it leaks then the tank doesnt build up enough pressure ? so it overheats? |
Aiden Cheese
TryHard QLD Soarer jzz30
Posts: 306 Reg: 09-2009
Michael Brown wrote on Monday, January 18, 2010 - 03:08 pm:oh ok so if it leaks then the tank doesnt build up enough pressure ? so it overheats?
Air in the system would stop circulation of cold fluid so yes. |
Michael Brown
Posts: 255 Reg: 07-2009
| Ah there lies one problem : / so i need a radaitor top tank and a new air flow meter |
Tom Richards
TryHard nsw V8
Posts: 297 Reg: 08-2005
| there is only one thing that happens with a cracked top tank. you lose "water', the engine overheats, you F$@@#* the engine. get a new radiator/ or top tank |
Boris Siljanoski
TryHard Western Australia Soarer GZ20 TT
Posts: 164 Reg: 11-2007
| It will leak and your engine will overheat. If you plan to keep the car for long time get a Koyo all alloy radiator and never have to worry about top tanks cracking |
Ross Bull
Tinkerer Vic V8
Posts: 23 Reg: 05-2009
| Having spent a considerable amount of time and frustration on fixing damage caused from a split radiator tank, I highly recommend you fixing it pronto! |
Myles Jantzen
Tinkerer SA SC 400 V8
Posts: 91 Reg: 08-2008
| It's easy to take out the radiator, do that and drop it off somewhere to get the top tank replaced (shouldn't cost too much) They will also clean it up for you. |
Michael Brown
Posts: 257 Reg: 07-2009
| Ahk thanks for the advice guys im gonna look into getting an alloy radiator |
Michael Brown
Posts: 258 Reg: 07-2009
| weres a good place to get an alloy radiator ? |
Tom Richards
TryHard nsw V8
Posts: 298 Reg: 08-2005
| http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310195649942&category=33602&_trksid=p4 340.m263&_trkparms=algo%3DSI%26its%3DI%252BC%26itu%3DUCI%26otn%3D10%26ps%3D63 us$130 + shipping us$128 total aus$290 delivered to your door. all alloy direct replacement, great looking unit replacing top tank is ~$350 which makes a new radiator for $290 a bargain. chris ryan in darwin recommended them in earlier posts. I have just fitted one. |
Myles Jantzen
Posts: 92 Reg: 08-2008
| That's a good deal! I paid around $200 for new top tank and clean. When I was looking was $500+ for alloy radiator. Just remember apparently you have to earth it and flush it every year or so to prevent corrosion. |
Michael Brown
Posts: 260 Reg: 07-2009
| so if i get an alloy radiator do they still need a top tank ? or do you put fluid straight into the radiator ? |
Chris Ryan
TryHard NT UZZ30
Posts: 251 Reg: 09-2005
| Michael, the link Tom posted above is a direct replacement for the standard V8 radiator, so it has a top tank, bottom tank, AT cooler bit down the bottom and the normal radiator bit in the middle (as you may have guessed). The difference is that the top and bottom tanks are alloy, not plastic, so no more cracking (hopefully). Highly Recommended replacement if you've cracked your plastic top tank. Just take the old radiator out, and replace with new shiny one. You will still need the plastic filler/bubble tank that the radiator cap goes on. Hope that helps, Chris. |
Michael Brown
Posts: 261 Reg: 07-2009
| thanks Chris yea helps heaps will have to buy one soon. |
Jamie Richards
TryHard St.john's v8
Posts: 113 Reg: 06-2009
| is there a radiator that is a replacement for the standard radiator that eliminate the plastic filler/bubble tank? |
Joe Russell
DieHard Manawatu 4.0 V8 GT-L (UZZ31)
Posts: 514 Reg: 10-2008
| The top tank is the plastic filler tank I'm guessing, as mine leaks and I'm having all sorts of problems. |
Posts: 11314 Reg: 11-2004
| If you want to replace the bubble tank, get one for the late model V8 as it doesn't have the level sensor, and hence doesn't get the same leaks. |
Joe Russell
Posts: 515 Reg: 10-2008
| That is exactly whats wrong with mine Peter. So leaking out of that sensor area will cause problems will it? If so I'll get a replacement quick fast. |
Posts: 11326 Reg: 11-2004
| Not a real problem, usually just means a slow leak and then the coolant looks ugly as it gets sprayed around the place. You might also look for a non-leaking second hand one, as new they are around $300. |
