  Soarer Central * Mechanical - V8 * Low reving Previous Previous    Next Next
Hays Sleiman
Reg: 11-2009
Tuesday, March 02, 2010 - 06:50 pm, by:  Hays Sleiman (Hays1530) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
Usually my car revs on 700 in park and neutral and 600 when in stationary drive. (or 700 with the aircon on)
Lately, sometimes when im stationary in drive it drops to 500 instead of 600 and with the aircon on it sits on 600 instead of 700.
Might not be a huge difference but it sounds like a WRX inside the cabin and feels like its about to stall.
The car is in good condition. No mods to the engine except for a BFI and I've never had mechanical problems.
I should mention I have an exhaust leak around the extractors area, it used to be bad until a bolt was tightened, but its still there. Could this be the reason due to lack of back pressure or anything like that? (Im still a newb, so go easy on me )
Cheers,
Hays
Daniel Blomfield
South Island
Soarer Limited V8 UZZ31
Reg: 02-2010
Tuesday, March 02, 2010 - 07:10 pm, by:  Daniel Blomfield (Soarer_nz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would say the exhaust leak would definitely be hurting it but also check your air filter cause if thats shot it won't help either (air in is just as important as air out) either of those is compromised and it will suffocate.
Mat Shiels
Reg: 01-2010
Tuesday, March 02, 2010 - 08:12 pm, by:  Mat Shiels (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
exhuast leak will definitely confuse things,
but check around the manifold for any hoses that may have been knocked off, there are a heap of them - and leaks after the MAF will confuse the mixture.
also might be worth cleaning your throttle body. i did this myself on the weekend. very easy, there are instructions on the web. but basically, take the intake off at the throttle body and with the car off, hold the throttle open and spray a heap of carby cleaner in there. then let it sit a bit and give it another squirt, things should start to loosen up, in particular off the back of the butterfly and the mating surfaces. then finally, with the car revving at about 2500, spray a heap more into the intake. then take a vacc line off the manifold and spray the rest of a can in there. the inside of your intake manifold should be squeeky clean and free of carbon now! helps with idle probs a lot. }
Hays Sleiman
Reg: 11-2009
Tuesday, March 02, 2010 - 09:16 pm, by:  Hays Sleiman (Hays1530) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much for a mechanic to do that? I don't have time as uni just started and im taking it in for its 100k service so might as well add it to the list.
Mat Shiels
Reg: 01-2010
Wednesday, March 03, 2010 - 07:50 am, by:  Mat Shiels (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
took me about 15 mins, and a can of throttle body/carburettor cleaner - which was about 18 bucks. so i'd say a mechanic would charge you about 30 bucks? its not hard at all, it' literally one 10mm bolt, and loosen a few clamps to get the intake off the throttle body.
and if i can work a 50hr week and still find time to do it, you can definitely do it while you're at uni!!! haha, when i did uni i had 12 contact hours a week, i had TOO much spare time.
Hays Sleiman
Reg: 11-2009
Wednesday, March 03, 2010 - 03:34 pm, by:  Hays Sleiman (Hays1530) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Okay, ill give it a go when i can. I've got 23 contact hours a week, plus two other jobs...believe me when i say i struggle for free time
But we'll see how it goes. My air filter is near new . So i'm gonna assume its the exhaust leak. Guess i won't know till i get that fixed...
Is there anything else it could be?
Daniel Blomfield
South Island
Reg: 02-2010
Thursday, March 04, 2010 - 09:17 am, by:  Daniel Blomfield (Soarer_nz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if you do use throttle body cleaner do it before you replace your spark plugs as that stuff will ruin your plugs. if you not replacing them i would advise waiting till your ready to or see if you can get some old ones to put in whilst you do it that stuff is good but it's not great for spark plugs
Friday, March 05, 2010 - 06:11 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shouldn't have too much affect on Iridium plugs - yeah it would probably be pretty bad for coppers.
Kim Hunt
Supercharged & Intercooled SC400\Soarer GT-L UZZ31
Reg: 08-2007
Sunday, August 08, 2010 - 11:43 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
had the same problem. i would look at your leads buddy, thats if it isn't your plugs
