Hey guys, my front air struts gave way a few months back, I replaced them with second hand ones which were in good nick.
I believe my drivers front height sensor is playing up because twice since replacing the struts the front right just dumps all the air and won't pump back up. I had to drive the whole way home from work with it sitting stupidly low.
I got out tried everything and then just let it sit and started it 3 hours+ later and it pumped up fine?
Another thing is, about 5 times now in the last month, I have got in my car and turned the key and I hear a click and nothing is on, I go to the engine back and press the negative terminal and everything is good, maybe just need to tighten it? I reset my ecu 2 days before this, will I need to do it again? because it is feeling a little more slow off the line.
Thursday, March 04, 2010 - 10:47 am, by: Mike Beck(Gold_40gt)
Hmmmm, sounds like the height control unit must have an issue, loose connection... water damage? age?.. Best to replace it with another one and see if that makes a difference.
It doesn't sound like theres anything wrong with the airbag itself.
Christian Somerville wrote on Thursday, March 04, 2010 - 10:26 am:
Get some CRC electrical contact cleaner, and clean the terminals, a bit of sand paper or something abrasive can help.
