Joshua Baldwin
TryHard victoria ucf-11 1uz-fe v8
Posts: 174 Reg: 10-2009
| i have heard of this been done, any body know anything about it? |
Goo Roo New Zealand E36 Coupe
Posts: 4513 Reg: 11-2005
| Nope, but I guess it is just a matter of using two plenums to make one with dual throttle body adapters. Should be an easy enough job for someone to do at an engineering shop. I believe you need to ditch the AFM and run two MAF sensors if you go down this path. |
Joshua Baldwin
Posts: 175 Reg: 10-2009
| i could possibly do it myself as im a welder/metal fabricator. i don't have a clear understanding of the MAF sensors what are they? how to install? how to get them etc. any help would be good |
Lew Radbourn
Goo Roo Queensland / Goodna jzs147 93 TT / uzz30 93'/
Posts: 3182 Reg: 07-2005
| after market computer and run a map sensor problem solved. it has been done the twin bodies. justa little bit of screwing around with the linkages. |
Goo Roo Victoria (The Nazi State) Active V8 and the Beast.
Posts: 2519 Reg: 07-2005
| It has been done. Can't think where I've seen any details, though. Maybe try www.v-eight.com |
Joe Russell
DieHard Manawatu 4.0 V8 GT-L (UZZ31)
Posts: 631 Reg: 10-2008
| I think these are from v-eight.com as well, do a google search I'd say. Heres a couple of pics(not mine):
Lew Radbourn
Posts: 3183 Reg: 07-2005
| Dan; Manny's and Jeff's race car has it done |
Andrew Ferres
Goo Roo WA '90 C-F Celsior V8, '84 Soarer V8
Posts: 1236 Reg: 07-2005
| I ran dual throttle bodies for a while, still have the manifold up in the shed somewhere. The power difference is negligible, however the mjdrange response is easily noticable. It was much louder too. Absolutely pointless on a stock ecu, as you'd still be sucking it all through a single AFM. I've got much better photos at home, but this is all I have here
James Buchan
TryHard Vic UZZ31 V8
Posts: 284 Reg: 10-2008
| Looks pretty cool! How hard was it to adapt the stock manifold to run dual throttles? |
Andrew Ferres
Goo Roo WA '90 C-F Celsior V8, '89 Crown Wagon V8, '84 Soarer V8
Posts: 1238 Reg: 07-2005
| I had a shop build it for me. I have some 'during construction' pics, but like the others, they are at home. |
David Eberhart
TryHard Q.L.D. V8
Posts: 238 Reg: 07-2007
| Joe is that an AC Cobra replica? WITH a TT 1UZ, crazy. Anymore pics? |
Andrew Ferres
Posts: 1241 Reg: 07-2005
| Those pics would be close to 10 years old now, so who knows exactly what happened to the car! |
