Guys I need help, just had a coil pack replaced and a day after i just lost power while driving. Had to tow it back home.I have checked the fuel pump and pretty sure the alternator is ok. Can anyone recommend looking at other things. I am just lost now.
Sunday, May 02, 2010 - 07:06 pm, by: Daniel Keogh(Xrfalco)
i had a similar problem with my old Twin turbo , it blew the injector fuse in the engine bay fuse box , same symptoms winding over no ignition . dont know if that happens with v8s? hope you sort it out
I checked all the fuses in the engine bay and they all ok. I got a feeling it's either a fuel problem or a electrical problem. I just need to know what the problem is though. If it's electrical then I should be able to sort it out but if it's mechanical then I am stuffed. Someone help please
Tuesday, May 04, 2010 - 08:23 am, by: Adam Foster(Adam)
check the fuses in the drivers side foot well if you blown a fuse there it could cause the problem. other than that i would be checking crank angle sensors
Sunday, May 16, 2010 - 01:50 pm, by: Rob Wilson(Rasjab)
Hi guys Mine had the same problem. Turned out to be the LV cable connector underneath the right hand coil pack was loose. Try taking the coilpack off, and see if the connector is pushed right in.
