Tuesday, July 27, 2010 - 07:17 pm, by: Brent Stewart(Bsm2122)
I am getting the oxygen sensor from an american site and it says the SC400 has 2 at the front and 1 in rear. Does the UZZ31 only have 2 front sensors or one rear and one at the front?
Tuesday, July 27, 2010 - 07:37 pm, by: John Stafford(Johng12)
My UZZ31 has 2 single wire oxy sensors which I just replaced from EBay Australia using a universal single wire oxy sensor (very cheap). The SC400 is an American version of the soarer that we don't have here even though many are labelled that way, really they are soarers, relabelled unless someone has imported one from the U.S. The U.S. has different legislations with regard to pollution control, which includes different oxy sensors, usually 4 wire ones. Hope this helps Cheers John
Phil Gibson Goo Roo WA '91 UZZ31 track bunky, '94 blk/blk UZZ31
Wednesday, July 28, 2010 - 09:26 pm, by: Dave Rose(Sand_groper)
Oh sorry Phil so the back ones are for ex temp only, someone with a late 32 s2 engine was telling me the one at the back was checking the o2 after the cat.so i have only got to replace two one day thank god.
Thursday, July 29, 2010 - 12:18 pm, by: Dave Rose(Sand_groper)
Nope I have got 4 02 sensors!!! had a look today, first two are in the ex manifold the next two are just before the cats and the EGT sensors after the cats and the last few 32 s had the same set up ...one set are heated i beleve.
Friday, July 30, 2010 - 11:30 am, by: Dave Rose(Sand_groper)
Some how you will have to keep the 4 o2 sensors, as i belive one checks the other ?? on a single pipe just put the rear left and right together in the pipe the first two need to go as close as you can to the four into one branch , let us know how you get on as we have a few late model owners on S.C.
Saturday, July 31, 2010 - 04:56 pm, by: Dave Rose(Sand_groper)
Bit more info..the two on the L/R ex manifolds are main oxygen sensors, the next two L/R just before the cats are the sub oxygen sensors all four are heated.
